Question about HP ScanJet 3670 Flatbed Scanner
Hp 3670 no longer scans to computer with vista 32 bit upgrade. Scanner will only scan out copies to printer. worked fine with windows xp
You can use Paint or a similar program to scan in a picture/document with your scanner.
Once in Paint you can select from Open the option of From Scanner.
You can change the size to fit the page in Paint and then save it to a file which can be opened and sent to a printer.
It's very basic, of course and it doesn't give you the options to set the scanner options usually found in the HP Toolbox.
Posted on Aug 11, 2010
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Have a hp f380 all in one deskjet printer with M/S Vista OS
Ofcourse, if there is any software or patch, there will be free on the HP website. However, as you have mentioned, that you are able to print, that shows that the printing software is working fine, to test the scanning part, please confirm that you are able to make a copy or not from the front panel of the printer by placing a text document on the scanner bed, close the scanner lid and then press color copy. If you are able to make a copy fine, that shows that the printer functionality is working fine.
The issue could be with the communication or with the scanning software. To check the communication between the printer and the computer, perform the following steps on the Windows XP computer or Vista computer, be sure that the printer should be connected directly to the computer via USB cable at the back side of the tower without any USB HUB, as you are using a Deksjet F380, it is a USB connectivity printer.
XP:
Follow the below steps to Scan using WIA (Windows Image acquisition)
1.Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2.Click Start then Click All Programs then Click Accessories then Click Scanner and Camera Wizard.
3.Follow the Scanner and Camera Wizard instructions to scan images to the computer.
Vista:
1. Press Windows logo and R on the keyboard*.
It will open a small run dialog box at the bottom left corner of the screen.
2. In the Run box type WIAACMGR and press enter.
3. Follow the onscreen insturctions and complete the scanning.
If you are able to scan fine using the above steps, then it shows that there is a communnication between the printer and the computer.
Please get back to me with the exact error message you are receiving when you try to scan from the computer, as to scan from the printer you should be able to scan fine from the computer (i.e., From HP Solution Center/ HP Director). So that I can assist you in much better way.
With Regards.
Mike.
Jul 03, 2009 | HP DeskJet F380 All-In-One Printer
Scanner Isn't Working
Well first make sure the scanning surface is clean.
If you're on XP, you could try the various patches/updates from the site here:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=77375&lang=en
You can also scan and copy in Vista by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (eg HP 1310) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 17, 2009 | HP Scanjet 5500c Flatbed Scanner
I have a HP 3180 and it prints just fine but will not scan and I have Windows Vista.
The all in one solution software you used in XP doen't work with Vista.
But you can still scan and copy by using Windows Photo Gallery.
3. Highlight your scanner icon (ie HP C3180) then click import.
Hope that helps.
Chris (ziraffa)
Jan 03, 2009 | HP Photosmart C3180 All-In-One InkJet...
Hp 1410v won't scan
3. Highlight your scanner icon (ie HP 1410v) then click import.
Hope that helps.
Chris (ziraffa)
Dec 21, 2008 | HP PSC 1410v All-in-One Printer
Scanjet 3970 and Vista
since This driver enables scanning with the Windows Photo Gallery on Windows Vista or the Scanner and Camera Wizard on Windows XP. some features may no longer be available when using this basic driver.feature driver for Windows Vista or Windows XP Professional x64 . You can upgrade to an HP product or driver that is fully compatible with Windows Vista or Windows XP Professional x64 that will support the additional features
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=298547&prodNameId=298549&
swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=sj-47402-1
Aug 22, 2008 | HP ScanJet 3970 Flatbed Scanner
HP Printer
Try this :-
Installing the printer driver in Windows Vista
Verify that the printer is turned on.
Connect the Universal Serial Bus (USB) cable to the printer and to the computer.
A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Print a test page to verify that the printer is working correctly.
Using the basic printer functions
Printing: - Open the document to be printed in the software application in which it was created.
Click File and then click Print.
Scanning: - Scanning with Windows Photo Gallery
Click the Start (c5af1ed.gif) icon.
Click All Programs.
Click Windows Photo Gallery.
Click File and then click Import from Scanner or Camera.
Click Import.
Click Scan.
Scanning with Windows Fax and Scanning
(NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise)
Click the Start (9c4e39e.gif) icon.
Click All Programs.
Click Windows Fax and Scanning.
Click New Scan.
Click File and then click Scan.
Scanning with Paint
Click the Start (b95b750.gif) icon.
Click All Programs.
Click Accessories.
Click Paint.
Click File and then click From Scanner or Camera.
Click Scan.
Importing and viewing images on a memory card
Remove the memory card and then re-insert the memory card into the appropriate memory card slot on the printer.
(NOTE: See the User Guide that came with the printer for more information on how to insert the memory card in the printer)
On the Auto play screen that displays, click Import Pictures, View Pictures, or Open folder to view files.
Follow the instructions that display on the screen.
Using the advanced printer functions
(You might find that some of the advanced features are no longer available when using this basic driver. You can upgrade to an HP product that is fully compatible with Windows Vista if the advanced features are necessary.
To help you decide what product to upgrade to, click here for information on upgrading the product go to this link or copy and paste it into Browser :-
http://h30216.www3.hp.com/ASA/Controller?adi_hasScript=1&_AD_195R22=110&adi_scriptSID=DF57657645AF158516628FE76C76392C&sysid=84&appid=10251&_ad_stoken=sup&jumpid=re_r10602_advisors/adi/sd
Jul 22, 2008 | HP DeskJet 3940 InkJet Photo Printer
Scanner Failure: HP Officejet 6210
After hours of trying things.I found this and it worked. The scanner button doesn't work, but at least I can scan.
?id=microsoft.windows.resources.expandarrow To scan a picture using Windows Photo Gallery
    Before you begin, make sure that you've installed your scanner on the computer and that the scanner is turned on.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Windows Photo Gallery.
  2. Click File, and then click Import from Camera or Scanner.
  3. In the Import Pictures and Videos window, click the scanner that you want to use, and then click Import.
Jan 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Deskjet F335 Scanner not working
Check this link for Windows Vista drivers. This is for the 32 bit version of Vista. There are also 64 bit drivers:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&cc=us&dlc=&product=1128297
Mike
Oct 31, 2007 | Microsoft Windows Vista Ultimate Edition
HP ScanJet 3670 Flatbed Scanner Logo
131 people viewed this question
Seeker5211
Seeker5211
