Question about Ovens
Hi, I have a diplomat double fan assisted oven and the element in the fan oven has gone,the bolts which hold the element in however, have a really shallow head on them and when I try to use a spanner or socket to undo them, it slips off the head, any suggestions?
  • Ovens Master
  • 3,463 Answers
If you cannot remove the screws from inside the oven, then there is really no alternative than to to remove them from the out side of the oven compartment.
If it is built in, this will entail removing irt from the oven hosing, and removing the rear panel of oven, to gain accessw to the element securing screws.
Posted on Jan 31, 2010
I have a Diplomat 600 fan assisted oven. When switched on, the fan can be heard running, but the oven does not heat at all. Any ideas please? Is this likely to be expensive to rectify?
Hi.
It is going to be a faulty oven element.
Remove the cover at the rear of the oven compartment, and see if there is a round heater element there, if there is, then it will be the element that needs to be replaced.
If no element there, then it will be either the top element of the oven , or rhe base element which is not visible, that is faulty.
If there is base element, then it can only be accessed from outside of the main oven by removing the outer panels, and is located at the bottom of the main oven.
Hope this helps.
Mar 11, 2011 | Ovens
How do i replace the heating element in a diplomat aca3200 oven?
make sure the oven is switched off.remove all trays etc from oven,remove 2 posidrive screws from bottom of fan plate,remove fan plate,the element is around the fan,remove 2 posi screws from where the element goes through the side of oven and the one screw that holds the top of the element to the back of the oven.slowly pull the element out and remove the 2 poz and neg spade connectors.refit as removed.
Dec 30, 2010 | Ovens
I have a diplomat 4510 electric oven, the pilot light is constaintly on even when the oven is not on,the oven does not heat up, i recently replaced the element
If you have replaced the element, and it does not heat up, then I would suspect the thermostat as being the cause of the problem, more so if it is the oven pilot light that is on.
To be certain, you really need to see if you are getting a feed to the element when you you set the thermostat.
Hope this helps.
Jan 31, 2010 | Belling XOU592 / XOU593 Electric Double...
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Fan oven element - HEEELLLLPPPPP !
one element, but you will need to open the rear of the oven to access and remove the 3 screws holding the fan and with a little bit of push and shoving you will be able to remove the screw behind the fan be careful the screw does not get stuck behind the fan. Putting the new element in will require bending the securing bracket slightly but don't worry it will straighten when you replace the screw behind the fan; which is easier to replace than when you remove it
Apr 18, 2008 | Neff U1721 Double circotherm Electric Oven
Can not remove element
Hi there. Dunno if you solved your problem but I had exactly the same. I did a bit of digging on this website and found the solution which worked. Basically, undo the three bolts holding the fan motor onto the back of the unit. This should allow enough play on the fan from the inside to wiggle (technical term) the bolt free and replace on the new element. Reposition and secure the motor. Hope this helps. Matt
Apr 02, 2008 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
147 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
