Question about Pioneer DEH-P2600 CD Player
Setting the time
I have a deh-p2600 and can not get the time set for some reason if anyone can help that would be great. email me at kjjk_4@hotmail.com
Hey i just looked at your ? and went and figured it out on mine wat u gotta do it turn it off shuld be the button bottom left beside the vol. nob then hold function down for a bit like mabey 4 to 8 sec then use arrows like u use for bass treb adjust to set time..
Posted on Apr 02, 2008
How to install a. Pioneer deh p2600 in a 1990 Ford ranger I have the harness and it's not working at all
I buy them at Best buy and have them installed there for just that reason. They have the adapters and don't share well with the public.
Aug 03, 2015 | Pioneer Car Audio & Video
I'm not sure which wires to splice together
Hello my name is Isrel. Here is a diagram that will help you out.
Aug 24, 2010 | Pioneer DEH-P2600 CD Player
Pioneer deh-p2600
Here you go. Use the link and download the diagram when you get there.
Good luck.
http://audio.manualsonline.com/manuals/mfg/pioneer/dehp2600.html
Jul 05, 2009 | Pioneer DEH-P2600 CD Player
Can not find a wireing diagram for a pioneer DEh-p2600
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
May 30, 2009 | Pioneer DEH-P2000 CD Player
Setting the clock
hold source button down to turn the units power off
once the unit is off hold down the F (function button) till you hear a beep from the unit once this has beeped press the F(function) button 2 or 3 times the clock should display flashing numbers
once you have this press the buttons to skip the songs to the hr once hrs are set press F (function) button one more time to select minute settings after this has been set..........hold down the source button till the unit powers back on and clock will be set on this unit
hope i was able to help you
have a great day
Mar 04, 2009 | Pioneer DEH-P2000 CD Player
Car CD Player Time Settings
Click on the link below and you will get step by step guide.....
http://www.pioneerelectronics.com/PUSA/Products/Setting+your+Clock#nav
Please do not forget to rate this solution
Cheers!
Nov 03, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Clock!!!!
For most Pioneer single CD players, you can set the clock using the following steps: 1.Press and hold the SOURCE button until the unit shuts off. 2.Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button. 3.Press the left or right arrow to select the segment of time you wish to adjust. 4.Press the up or down arrows to increase or decrease the numbers in the blinking segment. 5.Once the clock is set correctly, press the SOURCE button to exit.
Aug 26, 2007 | Pioneer DEH-P8500MP CD Player
Pioneer DEH-P2600 CD Player Logo
158 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
