Question about Frigidaire Dishwashers
Not getting any water in washer but sounds like it's trying
  • Frigidaire Master
  • 43,501 Answers
What you are hearing is the solenoid valve either opening and there is no water, or it is trying to open and cannot.
Take the very bottom front panel off of your dishwasher. You will see where the hose is hooked to the valve (often blue) in the one corner near the front. Take the hose off and verify that water will come out when you turn the valve to the hose on. Next check to make sure that there is not a screen that is plugged with dirt just inside the hose connection.
If you have water and everything is clear then the vlave is bad. These valves simply use a magent to lift a valve and let water in. If it sticks at all the valve will not lift. The only other option is that,
You will need to replace the solenoid valve.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Heatman101
Posted on Jan 31, 2010
WHY ON MY MAYTAG EPIC WHEN IT GETS TO SPIN IT JUST MAKES DRAINING NOISE AND WATER WONT DRAIN?
Sounds like your drain line is clogged. You may also have stuff clogging a water filter just before the pump, or the water outlet coming from the drum.
It could also be a problem with the pump, but until the drain line is opened up, you still won't be able to empty the water from the washer.
Aug 11, 2014 | Maytag EPIC MFW9700S Front Load Washer
My washer is not filling up with water. It is making a humming sound. Please Help me!!!!!
The inlet screen could be plugged where hoses connect, or water is not turned on. Humming is the solenoid not working or trying to work. make sure water is getting too the machine and try repeated off and on cycles with dial. replace solenoid if needed.
Feb 26, 2014 | Whirlpool LSR5132PQ Top Load Washer
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Water in drum
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Sep 29, 2009 | Samsung WF203ANW Front Load Washer
No cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
May 29, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Smell from washer sounds like water still in washer
neptune washers are the only front loaders that have a counter balance system and they do have water in them to do this. water sound is normal.
when you are having an odor, it is from using the wrong soap or too much of the right soap.
you need to be using "HE" type soap and dont use too much. what you are smelling is soap residues that are not getting rinsed out from the unit.
they do make a special cleaning tablet called "affresh" and it is designed to clean out these residues.
also your washer will have a " brush" type device around the front of outertub where the inner tub meet.
it is between the tubs and will collect debris and can look nasty when dirty.
clean all you can see and then try to run 1 cup bleach thru unit if you cant find affresh tablets. at lowes or sears.
then make sure you use HE type soap next time to prevent build up and odors.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 22062 will not cycle correctly
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
Nov 14, 2008 | Kenmore 22062 Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Windscreen washers
sounds like the washer pump filter is blocked up. This is a common problem.
Sep 05, 2008 | 2004 Ford Focus
Dishwashers Logo
109 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
