Question about Hifonics Brutus BX 1605D Car Audio Amplifier
My hifionics light turns on, but neither led turns on. What should i do?
  • 63 Answers
Check all your wires and connections. Make sure that your battery wire and your ground wire are connected.
Posted on Mar 06, 2010
Side LED turn signals
Please respond to my problem. William Hulkower.
Jan 27, 2014 | 2003 Chevrolet Suburban 2500
How does a Continuous Lighting LED Light work? How about Falconeyes DV-405V LED Light?
The continues lights are mostly integrated with the camera devices for capturing the video to stay light on until you turn them off. For more information you can also visit this stuff :
How Does Continuous Lighting Led Light Work How About Falconeyes Dv...
Dec 13, 2013 | Spyder Auto 2006-2009 Volkswagen GTI...
I purchased led turn signal lights for my yzf600 and they work but dont blink and also they turn off my front turn lights. i took out the indicator signal bulb and it still did not work
you need to get a relay to suit L.E.D lights, and as far as I know, you will have to run L.E.D lights(indicators) on the front aswell as the rear.
Dec 06, 2012 | 1997 Yamaha YZF 600 R thunder cat
LED motion sensor lamp, after installed, does not turn off, it is on all day long
usually motion sensor led lamp is a little different from general led lamp. the work condition will shift from general lighting to motion sensor light. The reason why installed, but can not turn off, might you install in the wrong way. You can see the installation details Pir Sensor Led Tube 4ft f328a61c-a223-4610-b54f-1ba4836154f7.jpg
May 28, 2012 | Home Security
I recently purchased a used 50' Hitachi 50V500a Ultravision HDTV. I've had it for about a week. Was watching it. Turned it off to run an errand. Came back. Tried to turn it on. There is power. No...
The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
Oct 15, 2010 | Televison & Video
LED Lights wont work
if the turn signal worked before try to change the wires to the led, make sure the positive is on the correct wire to the led.(switch them)
Also make sure fuse to turn signal is still good.
Apr 17, 2010 | 1982 Honda GL 1100 Innerstate Gold Wing
Need codes for rcr 460 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
VCR, DVD, SAT·CBL, ON·OFF,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
indicator light blinks four times
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
Cruise control turns off when using turn signal. Just install trailer wiring harness. 2007 Mazda 3 with LED tail lights
If this problem was not there before you installed LED lights that may be the cause, there may be a electrical spike from the LED high voltage circuit that turns the cruise off, you might want to call the tech support of the company that made the LED light kit.
Nov 02, 2008 | Mazda MAZDA3 Cars & Trucks
I'm missing the instruction manual for my RCA RCR460 remote control. I need the manual set-up instructions, and a list of all the potential codes to sync up to a Toshiba or Mitsubishi DVD player. Any help...
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box). Note: If you press an invalid key during the Manual Code Search, the remote does not respond and the LED indicator light does not blink. If you do not press a valid Manual Code Search key (TV, VCR, DVD, SAT·CBL, ON·OFF, GO BACK), the search times out after two minutes. When the search times out, the LED indicator light blinks four times and turns off. The last programmed code under that component key is retained. 2. Press and hold the component key (TV, VCR, DVD, SAT·CBL) you wish to program. The LED indicator light turns on and remains on. 3. While holding the component key down, press and hold the ON·OFF key. The LED indicator light turns off. 4. After holding down both keys for three seconds, the LED indicator light turns back on. 5. Release both keys. The LED indicator light remains on. Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the LED indicator light blinks, and the next code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the LED indicator light blinks four times and turns off, all codes have been searched. The Manual Code Search method is exited.) Press Stop when TV turns off.
Jul 06, 2008 | RCA RCR460 Remote Control
Hifonics Brutus BX 1605D Car Audio Amplifier Logo
111 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
