Question about ATI (100713004) (128 MB) Graphic Card
When i turn my computer on, it runs but the screen is all choppy. do I need a new graphics card or a new monitor?
  • 36 Answers
Neither you probably need a new display cord (the one that runs from your computer to your monitor). they are usually very cheap (around ten dollars). good luck!
Posted on Jan 31, 2010
Computer not recognizing new Philips monitor. It tries to run set up and the Windows Logo Screen shows up but it just goes back to the set up screen. I've tried each mode available.
It would seem something is stopping your computer booting and you suspect it is the monitor. It could be or it might be coincidence and the new monitor has highlighted software problems that have accumulated over time or perhaps your graphics card cannot deliver the performance your new monitor needs.
I suggest you test the monitor on a different computer to ensure it works ok and then try it on your own machine after fitting a different hard drive and reloading the operating system so you know it is clean and bug-free.
If that fails I suggest you try with a different graphics card.
Mar 23, 2015 | Philips 200P3G Brilliance 20.1" LCD...
How can i run 4 monitors to put out one total screeen.. ok lets say i take 4 montiors and put like two 15" monitors and stack them with antoher 2 under it so its a box of 4 .. 2 screens wide by two...
In order to do this, hardware wise, you would need 4 monitors and enough graphic ports to support them.
Older graphics cards may only have two graphic ports which means you would need to have 2 videos card installed on your machine in order to get 4 displays going.
On some of the new graphics cards, you can get as many as 8 ports on the same card meaning you could drive 8 displays with one cards.
Once you've got the right hardware, you can either use the manufacturer's software (ATI or nVidia most likely) to configure your monitors to run as one desktop or you can try using Windows built-in display settings. The key is you want to extend your desktop onto all the monitors and to tell your computer which screen you want where.
If you need any more help with that, let me know.
Mar 25, 2011 | Samsung Computers & Internet
Hooked Samsung SyncMaster 931BF monitor to laptop and the letters on the screen are choppy. I can play with the settings on the monitor but can't get the letters to line up straight.
This looks like a driver/resolution problem. Which laptop are you using? New laptops shouldn't give you any hassles, but older models don't always have the graphics cards to support all monitor sizes.
Make sure your monitor driver is installed on the laptop and that you have the latest graphics drivers installed for your laptop.
You can download the screen driver here: http://driverzone.com/device.php?id=55741
Then check that the resolution for your monitor is set correctly on your laptop under display properties. The native resolution for the screen is 1280x1024.
Hope this helps,
-LL
Feb 23, 2010 | Samsung SyncMaster 910T 19" LCD Monitor
Turn my computer and it starts up normally, however, the monitor never turns on. When I manually turn the monitor on it displays the Acer logo and then goes to the "no signal" screen for a few seconds...
Try the monitor on another computer or a friends computer, if it is working you may need a new graphics card.
Try the monitor first, if your unsure take the machine to a local computer shop for advice, or if you have a computer geek nearby ask them.
Aug 27, 2009 | Acer Computers & Internet
Will a dell dimension 2100 support dual monitors
Yes it will but that will also depend on your graphics card to a degree.
To do it properly you need to install a new graphics card and disable the on-board graphics card from the bios.
Your new card should support std VGA as well as DVI
DVI is also capable of being hooked up to many large screen tvs
Aug 20, 2009 | Dell Computers & Internet
Asus P4P800S-X IS RUNNING LCD SCREEN IS BLACK
First thing is check the monitor by replacing it with any working monitor. If that does not work remove the Graphics card and do the same. The problem will be either in the Graphics card or the monitor....sodeep
Apr 09, 2009 | ASUS P4P800S-X (610839118175) Motherboard
Monitor screen freeze with driver...
hi! you don't need to update the driver cause the problem is in your hardware. Graphic seems to be a bit grounded, try cleaning the contact pins of your AGP graphic card with eraser, clean it side by side and then put it back again to an AGP slot, then boot your CPU again. If it still the same, try it in another motherboard that support you graphic card just to be sure before we conclude that its the graphic card has the problem. Anyway if it still under warranty you can claim for a replacement to the store where you bought the graphic card.  Have a nice day!
Dec 28, 2008 | ATI RADEON X1650 Graphic Card
I have a HP s3020n slimline the pc is running but not sending any signal to the monitor
Well... try un-plugging the VGA cable... ie., the monitor cable behind the tower...... if u get a message on screen saying No VGA Input... can confirm there is no issues with the monitor...
if you are using graphic card in computer unplug that and connect the VGA cable to normal display card came along with the computer and try...
or if you have another monitor... u can try connecting that to the tower which is not sending the signal to monitor and try....
even then you get the same problem... get an new graphic card... (if you dont have other monitor try with new graphic card)
Aug 24, 2008 | Computers & Internet
The grafics on my computer are fuzzy. What's an easy fix.
There are many fixes that you can make to solve this problem. However the best way to fix this is to get a new video or graphics card. My computer runs on a NVidia Riva 128/128ZX graphic/Video Card and operates with a Gateway EV700 CRT monitor. The NVidia Riva 128/128ZX card is an older one, but is a very strong card, I'd choose any NVidia graphics card. You may also want to check for a new monitor like a flat screen LCD monitor, that may help clear things up a bit.
Jul 05, 2008 | Computers & Internet
Computer Moniter screen turned purple
This is a problem with the video cards hardware or the driver itself depending on your card you should updaate your cards driver from the appropriate site,right click the desktop>properties>settings>advanced>ada... will then see the name and manufacturer of your graphic card
go to the appropriate website and download the latest driver,here are the three main graphic card manufacturers websites
1) nvidia.....http://www.nvidia.com/Download/index.asp...
2)a.t.i.....http://ati.amd.com/support/driver.html
3)intel...http://support.intel.com/
other things to check are
1.make sure your graphic card is securely fitted and if power is required to the card,then check the power connector is securly fitted and inserted
2.try changing your monitors lead from the v.g.a connector to the d.v.i connector at the back of the card,the v.g.a. is a blue connector and the d.v.i. is a white connector,and the d.v.i requires a d.v.i to v.g.a converter
3.where applicable install any monitor drivers however these are rarely required
4.run the direct x diagnostic utility,press start>run>type dxdiag >press enter,then go to the display tab and run the "test direct 3d" test
5.finally check all cables are securly fitted
if after these tests and tasks you still experience problems then change the graphics card and run the tests again,if you experience more problems then a new video/graphic card is required
any problems let me know
good luck .......
"Don't forget to rate the solution"
May 28, 2008 | Gateway FPD2275W LCD Monitor
ATI (100713004) (128 MB) Graphic Card Logo
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
