Question about Dryers
I have a Maytag Atlantis. Model#- MDG7658AWW gas dryer. My issue is that the dryer starts to heat up ( the way it should ) at the begining of any cycle but cuts the flame after one minute & the dryer continues to turn. I replaced the Hi-Limit Thermostat & problem still exists. Would rather fix than buy new Dryer.
  • 619 Answers
Problem is not with the thermals. You gas coils on the valve have gone bad. Replace both of them and you will be fine. Very inexpensive repair. Part number is 12001349 at approx. $45.00.
Posted on Jan 31, 2010
I have a Maytag gas dryer MDG7658AWW. It heats but timer won't advance in any setting. I have taken the screws out of the moisture sensor and cleaned it both front and back and removed any lint from...
You either have an issue with your cycling thermostat, or the gas valve solenoids. I could get into a very lengthy explanation as to what to do to diagnose, but for what these two items will probably cost you to buy, I would change both.
Oct 15, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag atlantis gas dryer not heating up
I thank you need a new Heating Element Assembly part # Y308612 here is a image of the Heating Element Assembly
Jan 20, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Ihave a maytag atlantis gas dryer model mdg7400aww that when I first start it up it gets warm but then stops heating? what is the problem
The operator coils get hot and quit on these ,when they get a little age on them, quite difficult to diagnose. If the coil feels hot to the touch after failure then that is a clue. f00c98f.jpg
Mar 05, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Our dryer takes a long time to dry clothes. If the airvent that goes outside of the ouse is clogged...would that affect the dryer? Stupid question i know, but we have like 5 feet of snow outside, so it's...
Yes this would affect try time as your dryer is not able to move the moist air out of the dryer. That is probably your problem. The other issue would be gas coils if it heats at the beginning of the cycle and stops heating towards the end.
Hope this helps _MJ_
Feb 07, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer runs but no heat. gas dryer (maytag)
check the ignitor. depending on the model can be from $25- $90.00 This is what heats up when you start the dryer. like a pilot light on a water heater, only it doesn't stay on all the time.
Feb 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Gas dryer doesn't heat up
,when you start your gas dryer you should here two clicks, if so then your ignitor should begin to glow if two clicks and no glow [its your ignitor] but you can use a volt meter and make sure 110 volts at ignitor if voltage replace ignitor with new.if not two clicks then its going to be your thermal fuse its in the same area as the burner Therese two kinds[only one in each dryer tho],both white having two wires and small, one looks like a missile the other a fling saucer.ither kind you can put the two wires going to it to gether ,isolate them with tape and try heating.if heats replace.now if fuse you need to check for any blockage,inyou house or dryer.over heating can cause the fuse to open if i can be of more help you can email thru fixya God bless ,tom
Jan 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
170 people viewed this question
Top Dryers Experts
