Question about LG 37LC7D 37 in. LCD HDTV
Tv turns on but no picture for about five minutes
37 inch tv turns on but no picture for about five minutes.sometimes i have to turn it on and off several times to get the picture
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped (or not)please rate, thank you!tv turns on but no picture for about five minutes - dcefcd6.jpg
Posted on Feb 04, 2010
  • Baz Jan 08, 2011
    This was very helpful when I was fixing my 37 inch LG LCD (model LG 37LF65). I replaced the blown capacitor, put everything back together and the TV was back up and running as normal.
    59 pence for a capacitor and a soldering iron did the trick!
Sometimes when we turn the tv on it will power up but no picture
make sure cables are right because one could be loose or in wrong place
May 27, 2012 | LG 37LC7D 37 in. LCD HDTV
Fixes for a Polaroid TV thats not turning on
Hello:
37 inchs have a television of the problem is that it works like 10 minutes and turns off the image, has sound but no image, turn off and on again returns to normal work and 5 minutes the picture goes but still sound, can you help?
Oct 20, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
Sep 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Jan 31, 2008 | LG 42LC2D 42 in. LCD HDTV
Please Help
call a tech your tv needs to to be repaired the problem is in the power supply and related circuit.good luck.
Apr 07, 2007 | Sony KV-27FV16 TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
No sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Mar 31, 2007 | Sony KV-27FV16 TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
TV solution
You may have a bad solder joint on the horizontal driver transformer or somewhere else in the set. I found this problem with this transformer several times. Stargazer
LG 37LC7D 37 in. LCD HDTV Logo
2,631 people viewed this question
