Question about Lexmark C912 Led Printer
Duplex jam Our Lexmark C912's new personality trait: If you print a letter-sized, two-sided document, after the printer draws the paper back in again to print the second side, the paper jams in the duplexing tray. The paper is always stuck in the tray in the same position, askew at a 45 degree angle. Has anyone encountered this problem? If so, have a solution? Thanks!
  • fvann May 11, 2010
     I have jamming problems with tray one
Repalce dupliexer or check the duplexor gears as i ahd it at one point otherwose doa printer ressetr ans ee if problem clears up
Posted on Oct 31, 2008
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
Jun 19, 2012 | HP J4680 Office Jet All-In-One Printer
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
Can not get printer to copy 2 sudes of a paper
Try to unplug and replug the printer into the power source to reset it. When the printer turns on, try to copy 2-sided again. Refer to the Lexmark 7500 Series User's Guide for the step-by-step instructions on how to copy on both sides of the paper.
Notes:
  • Use only plain paper in Letter or A4-size. Do not make duplex copies on envelopes, card stock, or photo paper.
  • You cannot print duplex through the PictBridge port.
May 22, 2011 | Lexmark X7550 InkJet Printer
Lexmark E342n. The paper jams after it prints and before ejecting. Paper is not wringled when pulled out. I open the back door and the end is there. It is like it is using shorter paper then letter.
Power off the printer, check the entire paper path of the printer for any jammed sheets of paper or other obstructions. Remove any obstructions you find and try printing again. Check if the page setting may be incorrect or paper size and the paper size settings do not match and make sure that the paper size in the printer driver settings matches the paper in the tray.
For further assistance, please contact Lexmark Technical Support.
Jan 07, 2011 | Lexmark E342n Laser Printer
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Does the Lexmark X9575 print automaticly 2 sided with no manual feed. I have a 15 page document doulbe sided. How do I print this without babysitting the printer. Thank you
Your model supports automatic duplex printing using letter and A4 sizes ONLY. If you want to print two-sided documents on another type or size of paper, use the manual duplexing method.
1) With a document open, click "File" > "Print..."
2) Click "Properties" or "Preferences" or "Options" or "Setup" depending on your system
3) Click the "Advanced" tab
4) From the "2-Sided Printing" area, select the 2-Sided Printing option and then select either the "Sideflip" or "Topflip" option (sideflip is the setting most often used)
5) From the drop-down box, select Automatic.
6) You will see an "Extend dry time" option, which allows extra drying time between sides when you are printing on both sides of the paper. The Automatic 2-Sided Printing option affords enough time for the ink to dry on supported paper types in average air humidity. Under conditions of high humidity, or if the normal drying time does not allow the ink to dry completely, you should select Extend dry time.
7) Click <OK> to close any printer software dialogs that are open. This will take you back to the General Print screen.
8) Click "Print"
Note: To return to single-sided printing, return to the Advanced tab. From the 2-Sided Printing area, clear the 2-Sided Printing check box.
Jan 14, 2010 | Lexmark X9575 InkJet Printer
My manual was in a strange language. How do I
Your manual can be found here.
Printing on both sides of paper You can print on both sides of a paper; duplex. Before printing, decide how you want your document oriented. You can only use this feature with Letter, Legal, A4, US Folio, or Oficio sized paper.
Do not print on both sides of the special media, such as labels, envelopes, or thick paper to print on both sides of paper. It may cause a paper jam or damage the machine.
  1. To change the print settings from your software application, access Printing Preferences. (See Opening Printing Preferences.)
  2. Click the Layout tab.
  3. From the Double-sided Printing section, select the binding option you want.
    • Printer Default: If you select this option, this feature is determined by the setting you’ve made on the control panel of the machine.
    • None
    • Long Edge: This option is the conventional layout used in bookbinding.
    • Short Edge: This option is the conventional layout used in calendars.
    • Reverse Double-Sided Printing: Check this option to reverse the print order when duplex printing.
  4. Click the Paper tab, select the Paper Options.
  5. Click OK or Print until you exit the Print window.
If your machine does not have a duplex unit, you should complete the printing job manually. The machine prints every other page of the document first. After that , a message appears on your computer. Follow the on-screen instructions to complete the printing job.
Good Luck!
Jesse
Jan 06, 2010 | Samsung ML-2855ND Laser Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
Paper Type and weigth Fot Lexmark C912
Media paper weight: is 20lb or 75gsm.
Media type: card stock, envelopes, Glossy paper, Paper Labels, Plain Paper, Transparent.
Media size: A3, A4, A5, Banner up to 11.69"x36", Executive, JIS-B4, JIS-B5, Ledger, Letter, legal, Super Tabloid, B5, C4, C5 DL, 7 3/4 9, 10 Envelopes.
demension is in inches, you need to convert it to centermeter.
Oct 30, 2008 | Lexmark C912 Led Printer
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
Lexmark C912 Led Printer Logo
286 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
