Question about Dell 2300MP Multimedia Projector
Changed Lamp in Dell 2300MP. Sounds like a "computer hard drive" trying to work inside for around 60 seconds, then lamp warning light comes back on.
  • 3,741 Answers
Check out whether you have locked the lamp door properly and its not loose. you are not the only one facing this problem.there are many other users facing this same exact problem like yours. click this link directly.http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html ------ also click on this link for more help http://en.community.dell.com/forums/t/17754189.aspx --------- check out.thanks.keep updated.
Posted on Jan 31, 2010
I have a Dell 2300MP DLP projector. It lights up for about a minute then the light goes out. Both the Temp and Lamp indicators are glowing after the light goes out. The fan is working. Will just replacing...
Looks like there is power supply problem as well as the lamp.
1 Clean all filters
2 Check out power supply (usually a few capasitors need to be replaced)
3 Wuld be a good idea to check the lamp in wokring projector, but if the "Lamp" light is constantly on it is more likely a faulty lamp as well.
Mar 01, 2011 | Dell 2300MP Multimedia Projector
I put a new lamp in it and the lamp light still, is there
Did you go into setup and tell the projector that you installed a new lamp?
Jan 19, 2010 | Dell 2300MP Multimedia Projector
Bulb lights, shuts down after about 30 seconds
What you are describing is a lamp that has expired? How many hours? If over 900 consider new bulb
Jun 06, 2009 | Dell 2300MP Multimedia Projector
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Dell 2300MP Projector Lamp - "Orange Light"
I've heard it could be the ballast, check with Dell for replacements
-- Deft
Aug 21, 2008 | Dell 3200MP Multimedia Projector
Dell 2300mp projector
check this out...
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
DELL 2300 MP NOT TURNING ON
Have the same problem here. Have two of these units. Took the bulb out of the one that had the Lamp light on, and put it in the other projector. The other projector worked perfectly. I have three bulbs, they all work in the one projector, they all cause Lamp Light in the other one. The manual states nothing about hard resetting the unit. Also note that, the fans do not power up instantly on power on, they come on about 5 seconds after pressing the power button.
Aug 30, 2007 | Dell 2300MP Replacement Projector Lamp -...
Bad Lamp lights even with new bulb.
confirm that it is not made in china-because some chinese lamps is not good in life time.
Dec 02, 2006 | Dell 2300MP Multimedia Projector
Dell 2300MP Multimedia Projector Logo
158 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
