Tip & How-To about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
If your picture looks 3D then you most likely have a CONVERGENCE IC that is bad or a fuse that supplies 12vdc or 25vdc to that IC IS OPEN. Also keep in mind it could be a FRACTURED solder connections. The cost of the IC varies depending on which one it is.
If you don't have necessary tools
and test instruments, and can't do the job yourself, I would advice you to
look for a professional to troubleshoot the problem. Don't
attempt to work internal if you don't know the safety precaution of handling it, there some stored
electricity enough to hurt you with a little mistake only.
Hope I helped you. Have a nice day! Thanks for using Fixya.
