Question about Kitchen Appliances - Others
If I plug in two portable heaters in the same room the circuit blows Can I put in a bigger breaker?
  • 111 Answers
Not a good idea, your house wiring may become the fuse,try to find another curcuit to run the 2nd one, even if it's in another room,stay away from extension cords with electric heaters, if you have to use one, get a short 14 or 12 gauge cord, turn them off when nobody is home
Posted on Jan 31, 2010
Trips breaker
tripping breaker indicates over load or dead short
it could be from failed start /run capacitors on the compressor unit ( (most likely)or from vermin across the power board
I suggest that you have a technician inspect and quote on repairs
Jul 18, 2015 | Heating & Cooling
I have a Charmglow electric fireplace that does not heat nor does the blower work. The flame light does turn on and turns. Model # 6901050100 Cat # 409896 It worked then quit. tore it apart, it wo
Did your circuit breaker blow.in your electrical box. Check that first before anything else. Sometimes if you have anything else on the same circut as a heater the breaker will shut down.
Jan 05, 2015 | Heating & Cooling
New Treadmill blows ciruit breaker when turned on.
have the new tread mill checked under warranty as it should not blow breakers from new
Feb 13, 2018 | Weslo Exercise & Fitness
Room heater caused 15 amp circuit breaker to go bad. Can we update 15 amp circuit breaker to 20 am (similar to ones next to it)
Probable not, in order for you to install a 20 amp breaker, the wiring must be a #12 gauge cable.Check the power requirement of your room heater. It should be not more than 15 amps. Check and retighten the connections to the heater.
Install a new 15 amps breaker.
Nov 21, 2011 | Electrical Supplies
Compressor keeps turning on and off, I can hear it and it dims the lights showing an increase in power draw, it will blow the main circuit breaker to the house. Therefore it does not run enough to remove...
If when it's running it dims the lights in the room or entire house, The circuit breaker for the receptacle it's plugged into, is not a high enough amperage to carry the dehumidifier and whatever other electrical appliances that are on the same circuit. OR if your house is hold enough (1970's era), it may have aluminum wiring and its overheating .
If it's blowing the Main Circuit Breaker for the entire house and not just the circuit breaker for the receptacle it's plugged into, Stop using the dehumidifier immediately!!! Have an certified electrician check your home's circuit breaker panel and wiring. This could be a dangerous situation.
Mar 01, 2011 | Maytag M3DH30B2A Dehumidifier
We plugged in a small electric heater in the room with our Vizio plasma tv. All lights everything went out. I hit the breaker and everything came back on except the TV. No power at all. NO money must...
Hey Juuuudd..lol...not beatles...
Plug your tv into another outlet some where in another room and see if it works.
Check your tv owners manual and see if it has a "reset" button.
Usually, if this happens it because of the electric heater.
They tend to pull alot of power and blow power to your fuse box.
IE...if you have a 15 amp breaker and run 20 amps per say through it
it blows....or shuts off the power.....this happens alot at work with people
running heaters, lights etc.
if your problem persists let me know...good luck.
PS....don't run that heater...
Jan 26, 2011 | Televison & Video
Not getting enough heat from my panasonic fan heater
Since the heater takes in room air and then heats it, the heater coils inside may very well be clogged with dust & lint. Turn off the circuit breaker that feeds the heater. Remove the front cover and carefully vacuum the interior with a brush attachment. For those areas that the brush attachment can't reach use canned compressed air (like you clean your computer with) with a straw nozzle to blow the dust and lint out and vacuum again. Replace the front cover, turn on the circuit breaker and you should be ready to go.
Jan 26, 2011 | Panasonic WhisperWarm FV-11VHL1 Compact...
I have a large room in my basement where I would like to install four Marly 58" baseboard heaters to work off one thermostat. The units are rated at 1250 watts each for a total of 5000watts. I plan to...
Using the equation I = P/E where "I" is Amps, "P" is Watts, and "E" is voltage, we find that your 5000w circuit will have an Amperage of 20.83. A 22 amp tstat will work, it will just leave you no room for surges. I would suggest splitting the baseboard and using 2 thermostats. Hope this helps
Aug 10, 2010 | Marley Electric Hydronic Baseboard Heater,...
Computer/Motherboard Issues
buy a circuit protector for just ur computer and call a electrition
May 12, 2010 | Gateway 507GR PC Desktop
Kitchen Appliances - Others Logo
71 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
