Question about Refrigerators
Model GSH25JSRF SS The fan in freezer clicking and working intermittley, the augor in the ice machine and the water dispensor are only working part of the time. You can hear a clicking sound as the fan tries to turn on and the blade moves slow, but still turns on eventually.
  • 619 Answers
On this particular model the fan and all operations are controlled by the main board on the back of your Refrigerator. This is part number wr55x10942. Less than $200.00 and not hard to change out.
Posted on Jan 31, 2010
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
RE: GE model #gsh25jsrf ss. The water does not dispense from door. Can I fix this? Thank you.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Oct 31, 2009 | GE GSH25JFR Side by Side Refrigerator
G.E. Side by side model quit dispensing water. The refrigerator door was not completely closed overnight. Is is possible the water line froze since the freezer had to run so much
It is possible the water line inside the freezer door froze . Remove the bottom kick plate and follow the white tubing about 6" to a coupling . Push in on the white ring and at the same time , pullout on the tubing . Push the water dispensor , and if water comes out of the hose going under the fridge , this means the line is frozen in the door . If no water comes out , it means the water tank at the bottom of the fridge section (behind crispers ) is probably frozen . A hair dryer should work on the tank , but , a different procedure will be needed to thaw the door . Come back if door is frozen for the procedure .
Aug 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan noise
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
May 25, 2009 | GE GSH25JFR Side by Side Refrigerator
Not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Aug 28, 2008 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
250 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
