Question about Dell Latitude C640 Notebook
The power supply to my c640 has a green light that flashes when plugged into the laptop, if i unplug it from the laptop, the light stays steady and green, do i have aproblem, the laptop will not power up and i have put in a new battery
    Novelist:
  • 132 Answers
Is the battery charging when you plug the power supply? If not, while the battery and the power supply is plugged in go to BIOS, that will be F2 when your computer boots up, from there check on battery health or battery info you will also see the ac adapter if it's detected if it says unknown try to use another ac adapter if it is detected still try to use another adapter. If you still have the same problem after trying a new one. You'll need to replace the motherboard
Posted on Feb 12, 2010
Dell C640 will not power up w/ac ad
  1. Verify that the AC adapter brick is receiving power.
    Shut down the computer and unplug the adapter from the system first and then from the power socket. Wait 5 seconds.
  2. Plug the adapter directly into the wall socket, bypassing surge protectors, UPS units, or extension cords. The adapter LED should produce a steady green light.
  3. If you do not get a green light, try the adapter in another wall outlet in another room or verify that the first outlet works with a lamp or hairdryer.
  4. You can also isolate the power problem to a bad adapter by swapping it out with a second adapter - such as one for use with the port replicator.
  5. If the adapter LED lights, check the computer for bad connections.
  6. Examine the system power socket to be sure it does not have any bent, missing, or pushed-in pins.
  7. Plug the adapter connector directly into the computer, bypassing surge protectors, extension cords, etc. Be sure that the adapter connector fits tightly into the computer's power socket.
  8. If you have access to another computer like yours, try your adapter on it or its adapter on your computer.
  9. If your computer is still under warranty and the AC adapter does not respond to troubleshooting, please contact your computer manufacturer.
Jul 19, 2010 | Dell Latitude C640 Notebook
Power will not stay on to VIP 211 receiver
Hi! This is Matt Gonzales with DISH Network. When a receiver will not stay powered on properly, and you have tried unplugging it and also plugging it into a different outlet, the reciever will need to be replaced. When a receiver is on properly the green light should stay steady
Jul 10, 2010 | DISH Network ViP 211 DTV Receiver
Power supply light keeps flashing green and problems with tray op
under normal conditios power supply light should be a steady green light not flashing if not power supply is might be bad call (800) 4MY-XBOX
Oct 11, 2009 | Microsoft Xbox 360 Console
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
There is a flashing green light when i press the power button but the dell latitude does not boot
Just in case something got wiggled, try unplugging the power supply again, press in the power button and hold it in for a count of 10 seconds to dissipate any internal power, then open up the chassis again. Make sure that all the power connections that run from the power supply are seated tightly into the connectors on the board. Take the memory out again and make sure that you re-seat it tightly.and for more info http://tinyurl.com/m7ghqz
Jun 20, 2009 | Dell Latitude C640 Notebook
Dell c640 not charging battery
I have found a few things with this model, first if the laptop works on ac power when the battery is out then try pushing the button on the battery itself and see how many lights light up. If they are not green replace the battery it just wore out. Second if you can wiggle the power cord and you see the charge light flash on and off then the solder joints are cracked on the main board and you will have to take the main board out of the case and drill out the 3 rivets on the metal bracket covering the plug and bend it out of the way then there are a small brown and a small black block near the plug resolder the ends of these facing the plug. bend the bracket back into place and epoxy it where it was. put the main board back in the case hook all the stuff back up and now it will charge your battery. If you are not good at this stuff I would not try it yourself. I have fixed 2 c640s this way and it is slow careful work.
Jun 24, 2008 | Dell Latitude C640 Notebook
Dell c640 battery problem
This sounds like it is not getting enough amperage from the power brick- check which model power brick you have. I'm not 100% sure but the pa-6 family may not provide enough power to charge and run the laptop at the same time. the PA-9 should- if it's rated at 4.51 @20v - that works out to about 90watt. If you DO have a 90 watt power adapter and it's still giving the orange then red flashes- and will not charge when the laptop is off- you probably have either a bad battery, or the motherboard is faulty and has a bad charge circuit, or a loose power jack. What does pressing the little button next to the charge indicator on the battery do? Flashing every other led- 1,3,5 is BAD, so is 1 and 5. You also might have a 3rd party refurb- that had the guts torn out and is not properly "seen" by the laptop.
Dec 16, 2007 | Dell Latitude C640 Notebook
Latitude C640 is dead!!
I have the exact same issue. It's not the processor. If you have you power supply tested, you will probably find that it's not working anymore. The green light still comes on when plugged in, but it's not sending the "charge" to the notebook.
I have this issue with a couple of C640's. I've tested the machine by charging the battery in another (Pentium 3 Dell C600), then putting it back into the broken machine... woohoo it works.
Unfortunately I can't figure out why the power supply's keep on busting, I don't think that the power-supplies are faulty, or maybe they just get old, don't know, but the most obvious problem is probably something with the mainboard, which really sux.
Hope this helps,
Oct 09, 2007 | Dell Latitude C640 Notebook
Dell Latitude C640 Notebook Logo
172 people viewed this question
Alun Cox
