Question about Kenmore 15762 Dishwasher
Can I take the bottom part of the dishwaher apart
Dishwasher had buildup of soap scale and dishes are not getting clean
  • 619 Answers
Mkae sure you are running kitchen hot water faucet before starting dish washer. If not you are getting mostly a cold water wash thru out the cycle. Also make sure the jet dry dispenser is full. Always use the liquid jet dry as the small cubes you can get do not work nearly as well.
Posted on Jan 31, 2010
The trays in my 1-1/2 year old dishwasher seen to be plastic coated. They have now acquired a kind of lime scale buildup. What is the cause or how can I get rid of the build-up
First of all I am not paid to sell product but I can tell you the build up you have is normally soap. You can use vinegar, but I personally use a product called Lemi-shine. I add this to the soap (2 tablespoons) to the soap in the door for every load. This will clear this issue you have and keep the dishwasher clean like the day you got it. If you doubt this check out the Finish website as this will answer the questions you might have. Good Luck
Oct 09, 2014 | Refrigerators
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Film on dishes
the film on your elemend and dishes is more then likely soap residue.try useing less soap. if this is a new dishwasher it probably uses less water then your older one did so you will need to modify your soap usage. if you have had the dishwasher for a while then your valve is clogged or not opening all the way. check the brass elbow for mineral deposits and replace it and valve if buildup is seen
Apr 24, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwasher - soap dispenser won't open while washing dishes
A simple was motor is used to open that.
This video shows how to change a door latch but the dispencer basically does the same thing. HERE
Jan 15, 2010 | Kenmore 64802 Top Freezer Refrigerator
Dishwasher runs but the dishes aren't clean and low water pressure out of the arms dish soap left in the dishsoap tray
Try some Lime Away or high strength vinegar, to remove any scale from the pump. If it is not scalely, try to remove the spray arms to check if the pump has trash in it.
Sep 19, 2009 | Dishwashers
I have a greasy buildup on my dishwasher filter.
It is the grease left on dishes or pots & pans. It can be cleaned off using a good regular dishwashing detergent like Dawn in the sink, not in the dishwasher. To prevent it, scrape the dishes & pots better, and if possible, turn the temperature of the hot water up a few degrees. You should also change dishwasher detergents to a liquid, with a built in water softener.
Sep 05, 2009 | Frigidaire Dishwashers
Soap left in cups when cycle is over
If the problem is that the dishwasher isn't filling with enough water, you should replace the water valve.
If it's getting enough water, but dishes have a white film on them or are still not getting clean, you may have hard water build up in your machine. Try to run a dishwasher cleaner thru it, or depending on how much buildup you have, you may need to take the dishwasher apart and clean it. I know JetDry puts a cleaner out, but I haven't personally tried it yet.
You can usually see white buildup inside the dishwasher if this is your problem.
Apr 07, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
Kenmore 15762 Dishwasher Logo
191 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
