Question about Phil & Teds E3 - Charcoal Black Jogger Stroller
Hello, I need a replacement hood in grey black for my 4 year old e3, where is it the cheapest place to get one and how easy is it to fit? Thank you
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Try www.buggypitstop.co.uk they service and repair, and sell parts for Phil n Ted
Posted on Apr 27, 2010
"canon mp600..it's about 4 or 5 years old. It
The Power Supplies for the MP600 burn out over time. They are easy to buy and replace:
My MP600 Power supply died as well. Web searches (including Canon) turned up nothing. Called Canon. To order power supply from Canon, call: 866-481-2569 (credit card over the phone, no on-line interface). $34.49 with tax and delivery.
Note: the power supply has black tabs the you push away from the grey power supply case. One tab in front and one in back. The grey power supply box pulls right out of the printer. The internal connector (six colored wires) pulls straight out (there is no release tab/catch). Use small screwdriver or needle nose plyers to carefully remove. Pull/pry the female white nylon connector. Do not pull on the wires.
Jul 13, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Hello there, I have a Bosch Logixx dishwasher which I purchased just over 2 years ago. My upper dishwasher tray is not fitting properly into the hose pipe holes on the inside of the back wall of the...
Hello Deepak,
You can definitely fix this yourself, but I'm not entirely sure from your description which part is "dropping off". It may be a simple fix where something needs to be clipped back into place or you may need to replace something. Please can you take a look at the images below and identify which part you are having trouble with.
Below is the back of the upper spray arm which clips on to the upper rack. It has a grey plastic cover behind which is a large white plastic washer / gasket. The washer simply slots in to the back of the spray arm and the grey cover clips in over the top.
Your description suggests the grey plastic cover and/or the white washer are dropping off. If the grey plastic cover is missing, it may have fallen into the bottom of the washer under the lower rack, in which case you should be able to find it and clip it back on. If it's missing or wont clip back on, you will need to replace the upper spray arm as the cover and washer are not available separately.
This is the water delivery tube which clips to the back wall of the washing compartment. There is a metal clip which secures the tube to the wall. The open hole and one of the spigots slot in to the two holes in the back of the upper spray arm above. The spigot used depends on which height setting the upper rack is on.
Basically, everything simply clips together. If nothing is broken, you should be able to fix this at no cost by simply clipping the offending part back into place.
Hope this helps. If you need further assistance or help locating replacement parts, please let me know what needs to be replaced. Nearly all Bosch parts are available and in stock direct from Bosch.
Regards,
BElectric
Apr 13, 2011 | Bosch 24 in. SGS69L02 Logixx Built-in...
Need to replace headlight bulb 2007 hhr
H13 HALOGEN HEADLIGHT BULB, SOLD INDIVIDUALLY -- Low 55/high 65-watt halogen bulb; 12.8 volts; P26.4t base; A high quality, direct fit OE replacement headlight bulb
How to Replace a Headlight Bulb
(DIY Complexity: Easy / Time: 0.9 hour)
Parts:
1. Headlight Bulb
Tools:
1. Screwdriver
2. 1/4 in. Drive Ratchet
3. Socket Set
Steps:
Step 1 Open the hood and locate the headlight assembly.
o Tip: Most headlight assemblies have a place in the rear to gain access to the headlight bulb.
o Tip: It is recommended that headlight bulbs are replaced in pairs.
o Tip: Always make sure the struts on the hood can fully support the weight of the hood so that it does not close on you while working. The use of a hood prop can securely hold it in place.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 Gain access to headlight bulb.
o Tip: It is a good idea to check the high beam and low beam headlight bulbs at this time.
Step 3 Disconnect the wiring harness and replace the old headlight bulb with a new one.
Step 4 Turn on the headlights and check high and low beams to verify repairs.
Hope this help (remember rated this help). Good luck.
Mar 30, 2010 | 2008 Chevrolet Hhr
Changin the dust bag how do you do it?
1. open the bag compartment by lifting the black catch near the handle. 2. grip the grey plastic fitting on the bag, using the little handles on each side, and slide it out of the black holder. As you do this, part of the grey fitting remains caught in the black holder, and this causes the bag closure to cover the hole. When the cover is fully in place, if the grey bit doesn't release itself, you can help by slightly lifting the black tab where it's trapped. 3. slide the new bag in where the old one came out, and close the lid. 4. job done!
Jun 07, 2009 | Miele Cat & Dog 326i Bagged Canister...
Fuel pump relay
You'd have to read the manual, under the fuse cover, or go to a junkyard and compare with another vehicle. Silhouette & Lumina APV are the same as far as motors and electrical parts are concerned. just make sure it's the same engine size
May 26, 2009 | 1990 Oldsmobile Silhouette
Replacement covers for black and grey phil and teds
Hello there, I can get these for you (if you haven't got them already). The full set is £108.00, and the bumper bar cover is £7. P&P is £4.95
If you're interested please email me on elizabeth.higgs@mooshmedia.com
Thanks very much.
Feb 17, 2009 | Phil & Teds E3 Twin Seat Jogger
Phil & Ted E3 Explorer
You can buy replacement parts from Practicalpushchairs.co.uk. A new hood should be no more than £15 plus postage for either E3 or Sport models.
Jan 09, 2009 | Phil & Teds E3 Jogger
How to Fit a Cabin Filter
Hiya...the cabin air filter is located below the front passenger/windshield area.
It's only accessible by standing outside the Equinox with the hood open.
Here's how to do it...(before you pop open the hood)
1) Stand outside at the front-right door area.
2) Just below the front windshield area, pull up a few small black plastic clips that's on the black windshield wiper cowl area- a small flat screwdriver or a special clip-remover tool is handy.
3) Raise the hood up.
4) There may be a triangular-shaped hard foam sound damper at the left side nearby the hood hinge...pull it off if it allow you to work around it with ease.
5) Continue to find a few black plastic clips around the black windshield wiper cowl area.
6) Gently pull up the black windshield wiper cowl cover with care not to bend it too hard during removal.
7) You should see the cabin air filter inside that's held in place by a black rectangular box inside.
8) There's 2 black tabs that holds the cabin air filter in place.
9) Insert your finger or tool to pry the cabin air filter away from the tabs.
10) Remove old cabin air filter.
Remember to reinstall the clip parts back into place when you're finished.
Nov 12, 2008 | 2006 Chevrolet Equinox
Phill and Ted pram hood hard to put back in place
I have the same problem with a Phil and Ted's Sport - but I believe I have the solution as below. This is taken straight from the Instruction Manual which you can view at: http://www.arango-design.com/Phil-Teds-Sport-Buggy-p/7890-0001.htm - towards bottom of page is a link to the instruction manual - which I was unable to get on the Phil and Teds website. Got this today but haven't tried it yet. Hope this helps.
Really becomes clear when you see the pictures in the instruction manual.
Regards, John
Hood
The sport hood is packed disconnected.
To reconnect:
1. Locate sun hood and hold it facing down, as shown ‘a’.
2. Insert crimped wire ends into frame, through eyelets, ‘b’.
3. Lay hood back (to top of buggy).
4. Locate red coloured pocket at top of fabric seat and insert rear hood wires into each side, ‘c’ and ‘d’.
5.Open hood and attach domes, at bottom of hood, to main seat, ‘e’.
6. Pull eyelet at top of hood over pegs on each side of frame, ‘f’
Note that the windows in the hood are lined with a sun mesh of
a lower shade factor than buggy fabric. Always use sun cream
and clothing for protection of children in direct sunlight.
Nov 12, 2008 | Phil & Teds E3 Jogger
Fitting a new car stereo to the old wiring
hmm, this is an old post, do u still need help??
If u do lemme know and i'll give u a few tricks u can use.
Sep 28, 2008 | 1993 Volkswagen Fox
Phil & Teds E3 - Charcoal Black Jogger Stroller Logo
67 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Bill Boyd
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
