Question about RCA R52WH73 Projection Television
RCA R56WH78 appears to be having problems with fuse. The convergence control is not on the menu. Does any one know where I can purchase the fuse? and Is it easy to replace?
  • Kim Yearick
    Kim Yearick May 11, 2010
    What makes you think the fuse is bad? Send me more information and more detail and I will try to help you. hardrocko
  • 184 Answers
SOURCE: convergence problem
Yes, the convergence circuit can fail without blowing any fuses. These Tvs are tough to repair because the convergence output devices are transistors and there will be other small components damaged as well. Get an estimate from a reputable service center before going any further.
michtech
Posted on Feb 14, 2009
ladywinn
  • 5138 Answers
SOURCE: rca d52w23 convergence problem error code 84
Go to menu then setup does it have convergence on menu if not then you have a open fuse FL231 it will be the middle fuse there will be 3 of them on right side of FBT flyback transfomer.let me know!
Posted on Feb 16, 2009
Slinteriors
  • 8617 Answers
SOURCE: convergence problems with rca r56wh78 how can i fix it?
go to the following link and leave them a email with your model and symptoms and they will assist you with the proper component that will need to be replaced to correct the issue and they help with free instructions when you order the components.
http://servicemanuals.vstore.ca/
Posted on Apr 26, 2009
  • 147 Answers
SOURCE: 3d like picture, 3 colors bending across screen. convergence option gone from menu
There are bad solder connections on the flyback transformer and fuse #FL231 is open. Pretty hard to repair this yourself.
Posted on May 26, 2009
Ecollier2012
  • 3459 Answers
SOURCE: RCA 52 INCH CONVERGENCE PROBLEM HELP/already replaced the fl231 fuse
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
The picture on my RCA R56WH78 is blurried
thats the ITC222A chassis which is famous for deflection board issues which cause misaligned colors. You can get free assistance to figure it out by responding to this same post and leeting me know if you still have the auto convergence option still listed under the setup menu or has it disappeared from the setup menu options.
Mar 18, 2013 | Televison & Video
My R56WH78 tv has lost convergence overnite,I can not access any convergence menu with the remote control,What should I try next.
This RCA tv model have a dead convergence fuse at FL231 at the right side of a FBT- a big black plastic block with a wire hook to a board.Must resolders the FBT-(Flyback tranformer too).U have all the tools and also can do basic soldering work too?Yes,try website like Ebay.com to by the RCA tv convergence fuse to replaced at location FL231 and and also resolder FBT-Flyback tranformer too.Will solved this tv RCA model convergence problems.
Aug 02, 2011 | RCA R56WH76 Projection Television
WHY DOES'NT MY RCA MENU HAVE CONVERGENCE PROGRAM R56WH78 TURNED IT OFF FOR 10 HOURS TO REBOOT STILL NOT THERE
Blowed fuse on the deflection board FL231.06 amps it will be located on the right hand side of the FBT flyback Transfomer
there will be 3 of them in a roll small brown or gray rectangler looking caps but they are fuses it will be the one in the middle
Partstore.com has them. Deflection board is locted on left hand side of bottom chassis.
Jun 05, 2010 | RCA D52W23 52" HDTV CRT TV
May 26, 2009 | RCA R56WH76 Projection Television
Convergence problems with rca r56wh78 how can i fix it?
Apr 25, 2009 | RCA P52926 52" Rear Projection Television
RCA HD R56WH78 projection TV, picture just got ascew,
You are haveing form the sounds of it convergence problems. I see this all the time on this set at the shop. FIrst question in customer menu under setup do you have the convergence option if not consult the tips and tricks section under fl231 problem. if you do have this you may have other troubles the convergence is controled by three seprate boards.
Nov 08, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA R56WH78 3D Color Spectrum
Hello The common FL231 fuse problem that these set has can be identified by asking the question DO you have the convergence option under setup in the customer menu. If you do not then there is a 99 percent chance you have this. I have written detail repair instrucitons on this under my profile in the tips and tricks section of fixya. I use union electronics for parts but just google the part and you can find many distribitors of the fuse. should not cost no more than 5 dolars and if you can solder the repair shouldnt take more than an hour to complete. Be carefull and good luck. This repair is on you can do if you have any trouble let me know.
Nov 07, 2008 | RCA R56WH76 Projection Television
R56WH78 convergence problem
Get a new TV , i have had problems every year and now its off warranty, I will never buy an RCA again as long as I live,
May 13, 2008 | RCA R56WH76 Projection Television
RCA R56WH78
ok first question i have for you is.....in your setup options in the main menu do you have a convergence option... if you dont it is probaly a very specail fuse that lets the set know it is a projection tv with 3 tubes ...fl231... if you can get this fuse rca part #259213 and you can solder. i can tell you how to fix this and it will cost u 5 bucks and no more than an hour
Apr 28, 2008 | RCA R56WH76 Projection Television
RCA R52WH73 Projection Television Logo
689 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
