Question about Panasonic NN-H665 1200 Watts Microwave Oven
Panasonic microwave nn-h665wf turntable stopped rotating. Spindle does not rotate without glass tray and roller. Is there a fuse somewhere that I can replace? Otherwise the oven still works well. thanks!
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave Turn table rotates when door is open
Found this Panasonic post in the Samsung section!
If it moves just a tiny bit when the door opens and then stops, that's normal.
If it keeps running when the door is open, that's usually due to a bad door switch or broken / loose door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Any Panasonic parts not available locally can be had here: http://www.pasc.panasonic.com/epartr
We appreciate your thoughtful rating of our answer.
Posted on Nov 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave NN-6453B Turntable has stopped
(Does the control panel allow it to be turned off and on? You can usually find the owner's manual here.)
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
You can order Panasonic parts here .
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
jerryg50
  • 1689 Answers
SOURCE: Microwave oven NN-S573
The usual cause is the tray motor assembly, or the power supply that feeds it. These parts are available from the parts rep for Panasonic. Contact Panasonic for details.
There are serious safety issues when servicing microwave ovens. I suggest to have the oven professionaly serviced by an experienced service tech for these products.
Jerry G.
Posted on Jul 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Turntable Doesn't Rotate in Neff H5642 (1000w)
I'm sure your motor has failed.
Sometimes it a broken post inside the motor, if you like to tinker.
Otherwise I would contact Neff's service people for a spare.
Posted on Aug 25, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Microwave Model NN-S454 glass tray does not rotate
I would suspect that you have trouble with one of the door switches or its mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
See: http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
You can order other parts for this brand at Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Mar 06, 2009
Panasonic nn t945sfx
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Dec 05, 2013 | Microwave Ovens
Panasonic NNA873SB, turntable is no more turning
Dec 04, 2013 | Panasonic NN-A811A Convection/Microwave...
What is the dimension of the rotating plate I broke mine
Here is a link to the replacement glass cook tray for your Panasonic NN-S961 microwave:
http://microwaveglasstrays.com/shop/panasonic-microwave-glass-turntable-plate-tray-f06014m00ap-p-156.html
And here is another link to that part from Sears Parts Direct:
http://www.searspartsdirect.com/partsdirect/part-number/Panasonic-Parts/Microwave-Parts/F06014M00AP/0022/568/Model-NNS961/0789/0123245?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=50019470&diagramPageId=00001&productTypeId=x&searchModelNumber=NNS961&subCompDesc=Cabinet%20parts&brandDesc=PANASONIC&modelDesc=MICROWAVE&blt=11
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
As you can see from the website, the tray has the following dimensions:
Glass tray measures approximately 16 1/2 inches in overall diameter.
Outside diameter of turntable track is 10 7/8 inches.
I hope that was helpful to you, good luck and take care.
Joe.
Sep 06, 2011 | Panasonic NN-S961 Microwave Oven
Panasonic Microwave Model NN-H765BF will rotate occasionally and not rotate occasionally. If I manually rotate the glass plate, I can feel the gear reduction.
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
You can order parts Encompass here or call them toll-free at 866-779-5835.
Aug 22, 2010 | Panasonic Microwave Ovens
The microwave turning table hasitantly rotates and stops. the Model number is NN-S951BF - manufactures in April 2001
It may be that the wheels on the support may be a bit dry. You can use a tiny amount of cooking spray or cooking oil to try to lube it.
Petroleum-based lubricants are not advised in food preparation areas such as the inside of the oven.
You'll want to be sure the support and the floor of the oven are very clean before applying the spray.
If that fixes it, great, but if it fails again in a short time, then the support needs to be replaced.
May 29, 2010 | Panasonic NN-S950BA Microwave Oven
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
I have a microwave oven i purchased jan/07.Themodel#nn-s605wf,serial#6BN6040597,. mY TURNTABLE will not turn can you tell me why.THANKS
Remove the glass turntable, then the roller ring. Then seta glas of water in the unit and turn it on for 5 to 10 seconds. Look through the door window and see if the drive hub is rotating. If it is, then check the underside of the glass table to match up the drive hub. If it isn't turming, the drive, then it is internal and should have a 1 yr warrantee minimum. Remember, the, the turntable and drive must engage each other and the roller ring in place. Good Luck, and let me know please. One more thing, make sure there isn't a Turntable on/off swirch set in the off position. Good Luck, Ne
Oct 14, 2009 | Panasonic NN-H504WF Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Panasonic microwave nn-s963bf making grinding noise
You can
order parts for this brand from Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Mar 04, 2009 | Panasonic NN-S963BF Microwave Oven
Jerry G.
Apr 17, 2008 | Panasonic NN-S753 Microwave Oven
Panasonic NN-H665 1200 Watts Microwave Oven Logo
182 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
