Question about Connex CX-4300HP CB Radio
How many amps and volts to run connex 4300hp - Connex CX-4300HP CB Radio
  • 494 Answers
15 amps @ 13.8 volts
Posted on Feb 13, 2010
I have a connex 4300hp . I have power until i key up ,then it blows the fuse . What size fuse does this require ?
There are many reasons for it to blow a fuse .Putting one in that is higher in amps won't help ,all it will do is prolong the reason it is blowing fuses. One reason could be IC 5 thats blowing them.
Jun 23, 2015 | Connex Radio Communications
Connex CX-4300HP
remove top and bottom covers and locate the resistors on the bottom of the main PCB. Unsolder them and remove them ,thats it.
check out cb tricks for a picture of what to do .
Dec 13, 2013 | Connex CX-4300HP CB Radio
I have a connex cx-3400HP d and a r not working until the unit get's hot
Take it to a good cb shop radioactiveradios do really good work on connex radios
May 27, 2012 | Connex CX-4300HP CB Radio
My 4300hp will barely do 40 watts pep any help
is it always done this or just started? if always then theres a low wattage 2290 that could be installed @ factory and they will not do max wattage. exchange with newest production run to fix wattage. if it was doing 80watts and now down to 40watts have you checked swr's, antennna system, or power wires? if high swr's it will degrade transistors and loose wattage, and low ampres will not produce any power either...
Feb 18, 2011 | Connex 4300HP 240-Channels Base CB Radio
I bought a used connex 4300hp. i had it "so
IT could??? peak power, 14-15volts yeah.. the 4300 should put out 80w by itself.. as long as you have a low deadkey ie 1-5watts it should be fine. just don't put high wattage into an amp like that.. it will get hot QUICKLY.!!.. make sure your swr's are low low low.. 1.7:1 or lower... so your not getting reflected power... i would put a wattmeter with swrmeter like a mfj. or vectronic cross needle meter inline just to monitor it.... they go for $75 @ most places. Good investment... call email if need more help
Feb 06, 2011 | Connex CX-4300HP CB Radio
How do i peak my connex 4300hp?
They probably still have more experience then you do! You should be okay as long as you tell them that you just want a basic peak and tune. Nothing crazy. If you ask for super mod of some kind then you will end up with a radio with problems.
You can also send it out to have it peaked and tuned.
50 watts isn't bad tho. I have never worked on a connex and don't know much about them so I couldn't tell you who to peak it out.
Oct 14, 2009 | Connex CX-4300HP CB Radio
Low volt shocking
ouch! I have delt with this problem personally. every time i key'd up my astatic 636l i got shocked by the spring.
A shock in the mic is due to grounding problems. When you run the power a connex 4300 puts out and their is poor ground to the radio chassis itself it can cause shocking results! it will bight your lip, or shock the hand. no fun..... you SHOULD get some flat braided wire and run it from the radio body (metal part) (maybe where the mount knobs plug in) and make sure thats grounded. I dont know what powr supply you are using but a lot of them come with a screw or somewhere to ground the radio to.
See if that works it should stop your shocking problem.
it IS a grounding problem.
Jan 03, 2009 | Connex CX-4300HP CB Radio
This site is a joke trying to get operating manual NO LUCK
here is your manual in pdf form enjoy
http://www.cbtricks.com/radios/connex/cx4300hp/graphics/connex_4300hp_om.pdf
please give feed back for this I also hoop it is the right one.
Dec 16, 2008 | Connex CX-4300HP CB Radio
Connex CX-4300HP CB Radio Logo
170 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jim Y
Jim Y
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
