Question about Wahl 2 Speed Hand Held All Body Massager with Heat
Real loud noise when turned on - piece that attachments mount to is loose
What is making loud noise by front passenger tire when you go over bumps or turn? It's a very load creeking sound.
could be loose strut springs , strut shocky mount , top strut bearing, loose wheel bearings, suspension mounts.
have it inspected by an accredited suspension shop.
Mar 01, 2015 | Cars & Trucks
My drum is loose and won't spin even by hand
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Sep 21, 2014 | Whirlpool Washing Machines
Loud grinding noise when drum turns
Apr 20, 2014 | Asko Washing Machines
Hello. I hear a very loud thumping noise from the back of my 2014 Toyota Corolla as I slow down. I have taken it twice to the service station at the dealer and they hear the noise but cannot identify where...
Here are the only reason that can cause a thumping noise
  1. Wheel and Tire Problems
    • Wheels can become bent from striking objects, and tires can develop bulges from broken belts or wear. Both problems may cause a thumping noise. Thumping sounds caused by wheel and tire problems will typically increase in frequency at higher speeds, though the sound may not be heard at lower speeds. These problems can often be spotted by visual inspection.
    Suspension Problems
    • Worn or broken struts or strut mounts can create a thumping noise, especially when the vehicle hits a bump in the roadway. To test struts, bounce the rear of the car by forcefully pushing down on it and letting go. After letting go, the car should settle back to its original position without bouncing or noise.
    Loose Trim
    • Loose trim pieces near or in the wheel well can flutter in the wind while a car is being driven. These trim pieces may create a thumping noise as they strike other objects. A car owner can check trim pieces for looseness to determine if that is the source of the noise.
Hope this helps
Feb 20, 2014 | Cars & Trucks
Loud rattling noise when using my Epic 550.
It is most important that when assembling your system, all parts attached with screws, nuts, and bolts are fully tightened. That is true especially with the hand rails that are affixed to the Front of the platform to the rear. Recheck the motor mount and make certain it is solid. Every unit when assembled should be identical, however, if a part is not true (meaning it is bent, dented, etc.) it may not align 100% and make a noise when the device in in operation.
Jan 13, 2018 | Epic View 550 Treadmill
Noisy fan or motor?
HI. The most common issue here will be with a loose motor shaft. This is the part that the fan blades are mounted on. When this occurs, the looseness will cause the motor, and shaft to wobble, thus, causing this noise you here at high speeds. The wobble is less violent during the slower speeds, so it is not loud, in this case.
The second issue will be a warped fan blade. This will cause the fan to rub against the shroud, thus, creating the noise, as well.
If the shaft is loose, or bent, the entire motor will need to be replaced. Now, if the fan blade is warped, you can, simply, unscrew the blade from the shaft, and replace it(on most model)
Dec 11, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
Drum making sqeaky noise
The squeak is the rear bearing mount rubbing on the hanger ball. The plastic bearing is gone and that metal piece is cutting a groove into the ball mount. I have a picture. If the ball will be cut off and the drum will fall into the heating element and the belt will break. Not good!
8a3a785.jpgTo get to this bearing you must pop the top and get the belt loose,lift out the drum and inspect the bearing. The kit is fairly reasonable.This is something that a DIYer can easily handle.
May 11, 2009 | Frigidaire Electric Dryer
Open door position hold latch snaps real loud opening and closing the door
The hinge has most likely broken loose from the door frame. Look at the main body where the slider bar attaches to the body from the door. It is common for the hinge to break loose. It will need to be spot welded back into place to stop the clicking noise. Usualy two clicks when the door opens and then when it closes.
Apr 01, 2009 | 1999 Volvo V70
2004 Pontiac Grand Am SE1 loud noise
It is probably the wheel bearings they have been known for that.
Oct 26, 2008 | 2004 Pontiac Grand Am
Wahl 2 Speed Hand Held All Body Massager with Heat Logo
77 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
