Question about Amana Refrigerators
Freezer won't keep stuff frozen - Amana Refrigerators
  • 1,339 Answers
CHECK GASKETS , FAN AND THEN DEFROST THE FRIDGE, IF A LOT OF WATER COMES OUT OF IT , THE DEFROST HAS ISSUES COULD BE TIMER OR HEATING COIL. .. IF YOU DEFROST IT IT WILL WORK GOOD FOR A FEW WEEKS AND DO THE SAME THING TO YOU AGAIN
Posted on Jan 31, 2010
Why is the fridge and freezer not cold enough
If the fan isn't running neither section will be cold enough. There may be something jammed against the fan blade or the motor could be defective.
Jul 19, 2014 | Smeg FAB32RNN 50s Retro Style Black 304 l...
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
I need to know what size power inverter in watts and if they come with a car lighter plug
You won't do it. An inverter will keep a compressor running at maybe 200 or 300 watts but it won't start it up.
May 17, 2012 | Freezers
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
Refrigerator/freezer in garage doesn't keep food frozen in winter
Yes there is a solution. You need to install a garage Thermostat Heater. This will trick the thermostat into thinking it is in a warm environment. This article will tell you why this is happening and the solution as I described. Sorry but for some reason I cannot post this as a link. Copy & Paste into your browser. http://applianceparts.wordpress.com/2009/01/12/why-won’t-the-freezer-in-my-garage-refrigerator-freeze/
Dec 07, 2009 | Kenmore Freezers
Kirkland signature rifrig..freezer is icing up...everythig frozen solid...lower refrig only cool...milk souring in several days
that why it is called freezer, it supposed to frozen your food and make some ice on it, what is not supposed to build some ice is the allside of your freezer, but the food and others stuff should be frozen
Nov 06, 2009 | Refrigerators
Freezer box gets cold but fridge box stays warm.
Could be frost build up in the freezer compartment or a bad defroster,
Try running a diagnostic defrost cycle test and see what happens
Aug 17, 2009 | Refrigerators
Bottom freezer not keeping ice cream frozen
Check out freezer temp - should be around zero degrees. Fact that ice maker is still working would indicate that the temps are at least about 10 degrees. If the door seals are tight and the self defrosting mechanism is working properly, the unit may be low on refrigerant. I had similar situation where stuff was frozen but my ice cream was mushy even though unit was running 24 hours a day.
Apr 18, 2017 | Amana BX21V
Freezer not keeping things frozen
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Jun 12, 2008 | Freezers
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
