Question about Mitsubishi WS-65511 65" Rear Projection Television
Power goes on and off
T.V. turns on for 2 seconds and then turns off.
  • 1,476 Answers
I would need more detailed information on this unit to diagnose. Any odd sounds? Any blink pattern on standby light? Any strange behavior prior to it shutting down? Give me more info and I will see if I can help.
hardrocko
Posted on Jan 31, 2010
Monitor comes on and then immediately goes dark goes off
Your monitor's power supply is probably bad. If your inclined, you can pry apart the monitor shell and replace any bulged capacitors you see on the power supply. Replacement capacitors are available from mouser.com.
Mar 30, 2013 | Computers & Internet
Mitsubishi ws65713 picture goes out
I know these sets well, you lose brightness but still have sound?
If the green power light comes on for a few seconds and then goes out the set has a self check for error codes:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 02, 2012 | Mitsubishi Televison & Video
Will not turn on after manually pressing on button power is connected
TWO QUESTIONS:
1.) DOES POWER LIGHT JUST BLINK?
2.) IF POWER LIGHT COMES ON FOR A SECOND OR TWO AND GOES OUT, do the self check this set has:
when light goes out press and hold both the menu and input (device) buttons at the same time on the front of the set for at least five seconds and release both.
Power light in this case will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will help you.
SD TECH
Nov 26, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Monitor goes dark after about 2 seconds
I have the same monitor, its a power supply problem from the computer most likely. check the cable connections etc... I would get a service call from an authorized dealer near you ... about $120.00. Hope this helps:)
Jul 24, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Turns on for 2 seconds and then the video goes black. 2 years old
Your tv has a bad electronics parts on the section of the power supply. Need a service from qualified technician.
Jul 27, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
