Question about Cameras
It takes pictures but will not save it to the 4gb sd card.
    Brigadier General:
  • 11,967 Answers
Remove the card, go into the menu and find "format"...follow the on-screen instructions. Then, making sure the slide switch on the side of the card is in the unlocked position, insert the card. It should now work.
Posted on Jan 31, 2010
Gobii smartphone I can't save anything to the SD
The SD card you can use to put music on or pictures. You can't use it to save Apps or run apps. Apps and messages must be in the internal memory. And with 4Gb the internal memory is full before you know.
Sep 11, 2014 | Computers & Internet
Have a 4Gb memory card but when I put it in SD slot to take pictures, it always indicates CARD ERROR even whe the card is unlocked.
From what I see of the specifications for the NV-GS25, it uses SD cards. Your 4GB card is actually an SDHC card, which is electronically incompatible and will not work in devices not designed for SDHC cards. You need to use SD cards, 2GB and smaller.
Dec 15, 2012 | Panasonic NV-GS25 Mini DV Digital...
Vivitar itwist610dvr won't save files to my sd card
Unless you've found a VERY rare 4GB SD card, your 4GB card is actually an SDHC card. The 610 will not work with SDHC cards. Try using an SD card, 2GB and smaller.
Aug 16, 2012 | Cameras
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
I have a 4GB SD card in my camera, but it will only hold 30 pictures. I'm thinking it is something with the settings, but not sure how to change it. any suggestions?
When you take the card out, can you still view the 30 pictures? If so, these are on the internal memory of the camera which is very small. Your 4GB card should hold hundreds of pictures. If you want to save the 30 pictures, you need to go into the menu and find "copy" and copy the internal memory to a memory card. Then, remove the card, go back into the menu and find "format"...follow the on-screen instructions and erase the internal memory. Put your card back in and it should work properly.
Jan 23, 2011 | Canon PowerShot SD1100 IS Digital Camera
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
If the camera says the internal memory is full and won't allow me to take any more pictures, do I need to get a new card reader?
Your camera has only 32MB of internal memory, out of which only 13.5MB only is used for picture storage, which allows you to save only a few pictures. If you need to shoot more pictures you need to buy SD or SDHC cards or micro SD cards. If you buy micro SD card, then you also need to buy an SD adapter. SD adapte is very cheap, usually less than a dollar. The maximum size SD card you can use in Kodak Z915 is 32GB SDHC card. SD card sizes are available only upto 2GB. SDHC cards goes from 4GB to 32GB. Again these cards are rated based on their speed classes. It is preferable to buy Speed class 6 and above for good video recording. With higher speed class, speed increases. If you want to shoot pictures faster then you need higher speed class memory. Price of the card increases with the speed class. You can buy speed class 2, 4, 6, 8 or 10.
If you want to download your camera manual, try the following site:
http://resources.kodak.com/support/pdf/en/manuals/urg00995/Z915_xUG_GLB_en.pdf
Jan 14, 2011 | Kodak EasyShare Z915 Digital Camera
PNY optima sd card "card error"
You should try some photo recovery software to rescue the files on your camera card, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Jun 15, 2009 | PNY 4GB Secure Digital High Capacity...
KINGSTON 4GB MEMORY SD CARD
Check if your camera can support a 4G card. Some don't support than 2GB. if it supports, re-insert the card.
PS. If you have a card reader. Formatting once from your computer can help.
Jan 15, 2009 | Kingston 4GB Secure Digital High Capacity...
Iv just bough a 4gb SD card for my for my hitachi DZ-BX35E. When i try to format it though it said card error and doesnt complete the formatting. So i need some help please.
I'm not really familiar w/ your Video Camera. But you 4gb SD card can take about 24,000 still pictures. From what I understand, the SD card is only for take still pictures and not videos. The Video Camera is designed to use the Digital Video discs for videos. 4Gb might be too big for the machine to handle. Hope this helps but really I'm not sure. Check out this website which talks a lot about the Hitachi. A lot of techie stuff too you can use.
http://www.pixelbeat.org/systems/hitachi_DZ-BX35E/
Jul 18, 2008 | Hitachi Cameras
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
