Question about Frigidaire Dryers
I have a Fridgidaire Gas Dryer Model GLGQ2152ES0 that was working fine. I put in a new load, pressed the start button and all I get is a hum.
  • 1 more comment
  • Howard Rothstein Jan 31, 2010
    This does not appear to be the problem. The hum I get is an electrical hum as if a signal is being sent and a relay is humming but not closing. My wiring diagram talks about getting error codes by turning the cycle dial to 3 oclock pressing the start and cancel buttons simultaneously and then moving the dial to 2 oclock to read the digital error code. I can't figure out where the start point on the dial is to determine the 3 oclock or 2 oclock position since the dial keeps turning and has no stops.
  • Howard Rothstein Feb 01, 2010
    The solution offered doesn't address my problem. The humming noise I hear is like an electrical hum as if the signal is going out but something isn't sending the signal to the motor.
    The solution was right on. However, I do not believe it was the motor, I believe it was something that got stuck around the drum that had to be loosened.
  • 291 Answers
Try this, you will need someone to help you. Open the door, have someone push the start button at the same time as they push the door switch, while you reach in and turn the drum one way or the other. The dryer will only start in one direction, so if it doesn't start in one direction, try the other. Be very careful when you do this that you do not get your arm stuck in the dryer. Give it a quick push and get your arm out. If the dryer starts up, you have a bad start winding in the motor, and will have to replace the motor. If it does not start up then you probably have a bad control, but will need to have it tested to make sure. If the drum does start up like this, do not use the dryer until you have the motor replaced. Very dangerous. One more thing, if your hum is coming from the motor, and it continues for many minutes, without shutting down, you may just have a broken belt, or one that came off. You have a square access panel in the back lower corner, remove this and see if your belt is off. Make sure the power is disconnected first. If none of this works, then let me know whether the hum is coming from the timer/control area or lower, from the motor. Good Luck, Appliance Specialists
Posted on Feb 01, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa.
A common problem with noises from dryers has been the under wire that may come out of a bra. In dryers, they can get caught in one of the drum seals and make a scrapping noise, (remove power, grab a flash light and have a peek inside through the door opening) or the wire can actually pass through one of the heating duct holes at the back of the drum and touch something electrical like the heating element, thermostats. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Fridgidaire Gas Dryer - Mod.#FDG 546 RBS 0 Press start button just a humming noise, drum doesn't turn. Tried rotating the drum manually and it turns only with great effort so I don't think is't a belt. 12+...
Your glides are brobably broken and missing. This will make the drum hard to turn and bind the motor. Get the front off the dryer:
7411f19.jpgStart by popping the top with a putty knife.
Get the screws out that hold the front on and take a look:
Dec 16, 2008 | Frigidaire GLGR341AS Gas Dryer
Whirlpool gas dryer won't start
you most likely have a bad motor. Motors run around 100 dollars since the machine is 20 years old it would be a good idea to replace it with a new dryer. if i were you i would stick with a whirlpool product.
Oct 13, 2008 | Whirlpool GGQ8831L Gas Dryer
Gas dryer hums when I press the start button but won't start
hi thats a sign of a faulty motor . replace the motor thanks the appliance doc.
Oct 12, 2008 | Roper RGX4634KQ Gas Dryer
Dryers Logo
22 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
