Question about Frigidaire GLGR341AS Gas Dryer
Older Frigidare Elite Dryer conversion
I have a front loading gas dryer that is part of the Elite series. It's about 5 years old. I have moved from an area that has gas to propane. I've noticed a black soot build up in the dryer and think it's because it should be converted to use propane. Is there a conversion kit? I don't have the serial number handy.
    Novelist:
  • 131 Answers
You'll have to contact Frigidaire to see if a conversion kit is available. Normally, it's just an orifice replaced on the gas valve.
Posted on Mar 10, 2008
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Can you covert convection ovens from propane
Determine the make and model of your dryer. You want to make sure you get the correct conversion kit for your dryer. Get one that is specifically for your dryer, not a universal kit.
Buy a conversion kit for your dryer. You will probably find one at a local hardware storemag-glass_10x10.gif .You can also find them online. It is probably advantageous to buy it locally because the dealer has experience installing these and can be a great asset. The kit will probably come in an envelope and will be marked something to the effect of “Conversion Kit Nat. Gas to L.P. Gas for XXXX series dryers”.
1)Shut off the gas supply to the dryer and make sure the power cord is unplugged.
2)Access the gas controls assembly in the dryer. This will be different for different brands of dryers. The instructions with the conversion kit should tell you exactly how to do this for your dryer.
3)Turn on the gas supply and check for leaks using a liquid soap solution and / or a leak tester.
4)Activate the dryer gas valve. Check to make sure the manifold pressure is correct and if not, adjust the regulator setting. Again, check for leaks.
5)Adjust the main burner flame as directed in the instructions with your gas conversion kit.
Aug 28, 2009 | Blodgett Ovens
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
How do you remove top of new washer so dryer will sit on top?
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
Front loading dryer making a'sandy, grinding' sort of sound
possible problem has a dent on top of panel and is grinding on drum and top panel ,, do not put anything on top of dryers ,,,
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Frigidare Front load dryer 417.93042203
The front panel clips usually hold by friction. Just pull gently on the upper corners and it should hinge down.
Aug 08, 2008 | Kenmore 73952 Gas Dryer
Dryer does not heat up
Sounds like you might have the gas coils going bad. Not that expensive for repair, and parts arent that much either. Worse case would be a control board has went bad, but not likely. Gas coil part number is : 694539, and 694540. Also, you may want to check to see if the ignitor is glowing, that part # is 279311. Good luck and let me know if that doesnt help you.
Feb 12, 2008 | Dryers
Frigidaire GLGR341AS Gas Dryer Logo
141 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
