Question about Philips Health & Beauty
The blades wont turn around when its turned on it just clicks once and then does nothing
  • Philips Master
  • 1,610 Answers
It sounds like one of the blades is damaged causing them to lock up. Take each of the heads out andturn the blade insice the comb with your fingers on each one. They should turn freely. I speculate that one of them is damaged and the blade is embeded into the comb not allowing it to turn. If this is the case, you will need to replace the heads. You did not mention your specific model number so I cant direct you to the correct blades that you require. You should be able to find blades for your model at shaveroutlet.com
Posted on Jan 31, 2010
2320 wont maintain rpm when mower deck is engaged drops to 1500 or less and stalls out motor. everything seems to be turning properly.nothing obstructing blades
Would check blade spindle bearings, loosen belt to deck and try to spin blades they should turn freely if not probably bad bearing in spindle.
Oct 10, 2017 | Garden
Kawasaki 430V engine stops under engaging cutter blade but runs smoothly on idling
Could be a couple things, try turning the blade by hand to see if it will turn fairly easy. If it doesn't check around the blade base to see if something is wedging around the shaft like weeds or a piece of wire or rope or something. If there's nothing there check the belt maybe the idler has a frozen bearing [if it's got one] or maybe the belt jumped off and is wedged in there around the shaft. good luck
May 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Car wont start just clicks once then nothing
try cleaning the battery posts with a post cleaner or sandpaper. clean all the connections and ground wires..jm
Oct 04, 2013 | Chevrolet K2500 Cars & Trucks
Wheels won't turn, runs and blades work
if by turn you mean they wont rotate, then check if parking break is on, if you mean you cant turn the steering wheel, or cant make make it go around corners, then check the linkage
Apr 20, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
Ninja blender blade wont turn with food in container.
make sure blade is pressed tightly onto shaft... should click into indent. if not then you need a new blade piece.- stripped
Aug 18, 2012 | Blenders
Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Jun 16, 2011 | John Deere Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Mower blades not engaging
is the mower belt on the pulley ?
Jun 12, 2009 | Garden
Health & Beauty Logo
484 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
