Question about Gateway 838GM (RB838GM) PC Desktop
Windows has found problems with the Hard Disk that
My computer wouldn't boot again and after about 5 tries i finally got it to work under "Most Recent Settings". A Disk Check was executed and on the third part of it (there were only three on this check) it said "Not enough sufficient space to fix Data Stream" or something like that. It repeated saying that about 5 more times. It continued to Verifying the USN Journal and after it was finished it said Windows has found problems with the Hard Disk that cannot be fixed.
  • 30 Answers
Your drive may be going bad, it may be time to consider a replacement.
Posted on Feb 02, 2010
Hi I've got this problem with my Acer Apires laptop "a disk read error occurred, press ctrl+alt+del to restart. I keep pressing those buttons and the same things come over and over again what should...
Hi
that seems your computer cant boot from hard disk '
you can solve it by :
- be sure that nothing in cd drive and there's no flash memory in notebook.
- when you press start button , click F2 to enter set up and go to boot options and assign the first boot to Hard disk drive.
- if that don't help try to repair your windows ... or re install it
- final may be your notebook hard drive corrupted.
I hope that helps you
Apr 25, 2011 | Acer Aspire One PC Notebook
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Sandeep
Mar 19, 2011 | Computers & Internet
I am getting a disk 1/0 error and am not confident at all with computers. How can I fix this so my son can use the computer? My PC is about 6 years old and I only ever used it 9-10 times
A..Access the BIOS setup by pressing the key designated for your BIOS at Startup? It can be Del/F1/F2 or whatever and will be shown on Boot Screen before Windows is loaded.
B. Do you have a Win98 Boot Diskette proven to work well in a PC?
If so:
1.With the Win98 Boot Diskette in the Floppy Drive, Restart the PC.
2. Press the BIOS key [Eg:Del] enter BIOS setup
Check for correct YYYY/MM/DD and Time for your Time Zone and proceed to take a good look at the entries of your IDE devices and Floppy Drive with special attention to your Hard Drive(s) in IDE section. If they are all properly identified and normal, you can EXIT the BIOS. [ It does not mattere "Save changes" or "don't save changes" as you have not made any changes.]
3. Wait for Boot Disk to be accessed and Windows Startup Menu to appear with the Options:
1.Start Computer with CD-ROM support.
2.Start Computer without CD-ROM support
3. Help File
4. Select the option,1.Start Computer with CD-ROM support. and ENTER
5. Watch the screen for CD-ROM driver installed successfully" and "Diagnostic Tools " installed and CD-ROM drive letter designation and finally appearance of A:\Prompt
6. At, A:\ Prompt type FDISK and press ENTER.
7. Accespt Y at the bottom of "Large Disk Support" message.
8. At FDISK menu select #4. Display...."
9. Check if the HDD is shown as C: A FAT32 and size.
I am suspecting a problem somewhere here; so if you don't have an Active C: drive press ESC >ESC and remove boot Disk CTRL +ALT+ DELETE to reboot and post back
If you have an Active C: drive, press ESC >ESC to A:\Prompt and type in C: and then at C:\> prompt, type DIR and [ENTER] look for Windows Directories. Here is another Problem area. If you cannot Find any Dir or get an Error, make sure your typing and spacing are OK [ No space after Drive letter for the Command] and if so, ALT+CTRL+DEL or Power Off.
If the problem is same do next .
Alternative Start Mode
1. Re-boot PC, as it starts tap F8 several times until the windows boot window appears.
2. Scroll to "Start with last known good configuration.)
3. Press "Enter"
Or
2. Scroll to "Safe Mode" (With networking, if you want to access the internet)
3. Press "Enter"
System Restore
1. Go "Start"
2. "All programs"
3. "Accessories"
4. "System tools"
5. "System Restore"
6. ensure "Restore to an earlier time" is checked and click "Next"
7. Select an earlier date when your PC worked well. (Must be a highlighted date)
8. Click "Next"
9. Allow system restore and reboot
NTLDR is Missing.
Related errors:
Below are the full error messages that may be seen when the computer is booting.
NTLDR is Missing
Press any key to restart
Boot: Couldn't find NTLDR
Please insert another disk
NTLDR is missing
Press Ctrl Alt Del to Restart
Cause:
Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and/or NTDETECT.COM file.
Misconfiguration with the boot.ini file.
Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
New hard disk drive being added.
Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable.
Solutions:
CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Verify that your computer hard disk drive is properly setup in the BIOS / CMOS setup. Improper settings can cause this error. Additional information on how to enter the BIOS / CMOS setup can be found in document CH000192.
Windows 2000 users
Windows XP users
Windows 2000 users
If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers.
Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516.
Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Windows XP users
Insert the Windows XP bootable CD into the computer.
When prompted to press any key to boot from the CD, press any key.
Once in the Windows XP setup menu press the "R" key to repair Windows.
Log into your Windows installation by pressing the "1" key and pressing enter.
You will then be prompted for your administrator password, enter that password.
Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Edit the boot.ini on the root directory of the hard disk drive and verify that it is pointing to the correct location of your Windows operating system and that the partitions are properly defined. Additional information about the boot.ini can be found on document CH000492.
If you are getting this error message while you are attempting to upgrade to Windows 2000 or Windows XP from Windows 95, Windows 98, or Windows ME running FAT32 please try the below recommendations.
Boot the computer with a Windows 95, Windows 98 or Windows ME bootable diskette.
At the A:\> prompt type:
sys c:
After pressing enter you should receive the "System Transferred" message. Once this has been completed remove the floppy diskette and reboot the computer.
If you are attempting to add a new hard disk drive to the computer make sure that drive is a blank drive. Adding a new hard disk drive to a computer that already has Windows installed on it may cause the NTLDR error to occur.
If you are unsure if the new drive is blank or not try booting from a bootable diskette and format the new hard disk drive.
It's possible your computer's hard disk drive may have a corrupt boot sector and/or master boot record. These can be repaired through the Microsoft Windows Recovery console by running the fixboot and fixmbr commands.
Additional information and help in getting into the Microsoft Windows Recovery console can be found on document CH000627.
If you have tried each of the above recommendations that apply to your situation and you continue to experience this issue it is possible you may have a seriously corrupted version of Microsoft Windows. Therefore we would recommend you reinstall Microsoft Windows 2000 and Windows XP.
If you are encountering this issue during your setup you may wish to completely erase your computer hard disk drive and all of its existing data and then install Microsoft Windows 2000 / Windows XP. Additional information about erasing the computer and starting over can be found on document CH000186.
This issue has been known to be caused by a loose or fault IDE/EIDE cable. If the above recommendation does not resolve your issue and your computer hard disk drive is using an IDE or EIDE interface. Verify the computer hard disk drive cable is firmly connected by disconnected and reconnecting the cable.
If the issue continues it is also a possibility that the computer has a faulty cable, try replacing the hard disk drive cable with another cable and/or a new cable.
Hope this helps ,
Jan 26, 2011 | Gigabyte GA-8SRX Motherboard
When switcthing on my Advent netbook it comes up with the error message Windows Boot Manager Windows Falied to Start. A recent hardware or software change might be the cause. To fix the problem: 1....
Hi sioban_bros,
Based on your situation. I suggest trying the following steps:
1. restart the computer and keep pressing F8; Use Last Known Good Configuration.
2.If the issue still occurs after that, I suggest testing if we can boot from a Windows XP disk. If so, please install Windows XP on another partition and access your important data.
3. After backing up those data, you can use Windows XP disk to format the drive and reinstall your preferred operating system.
4. However, if we cannot boot from a Windows XP disk, the issue can be caused by incorrect BIOS settings or damaged hardware. I recommend contacting your computer manufacturer to check BIOS and hardware.
To access the data on the drive, you can try to install the hard drive on another computer.
Hope it helps.
Please rate this solution if found useful.
Best regards,
Reyjoshua07
Jan 17, 2011 | Advent Netbook
No operating system found
just try to repair your OS if you are using windows xp. use that repair option after F8 during installation of XP.
Jan 07, 2010 | Compaq Presario Notebook
Thinkpad 390x 2626, won't boot from cd drive
Try pressing F12 at startup, you should get a boot option.
Nov 19, 2008 | Computers & Internet
Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Aug 26, 2008 | Toshiba Satellite A70 Notebook
Operating system not found
On my Windows 7 laptop, I have got "Operating System not found" error. to fix problem, Windows Boot Genius helped me finally!
Mar 15, 2008 | Gateway M305CRV Notebook
Error - The Hard Disk Was Not Found
Boot into the BIOS, I think you hit the Delete key on Dell's to get into the BIOS, but I'm not sure. You should see some type of message at boot that says "To enter setup press XXX" Where XXX is the Delete key or some other key.
Once you're in the BIOS setup see if your HDD is listed. You may also find the option to reset the BIOS to default. Generally speaking this will not hurt anything and may be worth a try.
Dec 19, 2007 | Dell Precision M60 Notebook
Computers & Internet Logo
41 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
