The lights come on my air con sogo ss- 37 sac
The indicate lights continually flash on my air con sogo ss- 37 sac split can anybody help please
bobotfel
  • 236 Answers
SOURCE: I have a Fujitsu Split
Try to disconnect the supply from circuit breaker for 10sec. and "on" again, if it doesn't work you need at qualified technician for that problem.
Posted on Apr 16, 2008
refritech08
  • 149 Answers
SOURCE: Samsung aqb09jjwc/uqb09jjwc split type air
possible defective thermistors there are 2 of them
Posted on May 09, 2008
  • 400 Answers
SOURCE: RECOMEDENT SIZE OF ROOM TO USE SPLIT UNITS FROM 12000BTU TO 24000
650btu/square meter
Posted on Mar 25, 2009
  • 10865 Answers
SOURCE: unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
Posted on May 25, 2009
SOURCE: Mistral Air-con split system shows F6 fault! What does it mean?
F6 INDICATION MAY MEAN THAT THERE IS A PROBLEM WITH THE BLOWER MOTOR. WHEN THE BLOWER MOTOR GETS HEATED UP (WHEN ITS WINDING BECOMES WEAK) THIS MAY HAPPEN. SO U GET UR BLOWER MOTOR AND PCB BOARD CHECKED.
Posted on Dec 31, 2009
My gree split system air con won't recognise the remote control
I would check settings on remote firstly . Ie if you require cooling set it to cool or snowflake. If it still doesn't open up this usually indicates a fault and May need resetting at CB. P.s you can check your remote by using your phones camera just point the ir at the camera while on, you should see light flashes which indicates the remote is working
Nov 27, 2013 | Heating & Cooling
Air con dead
Larger split system air con gets power from the external unit while smaller air con gets power from the internal unit. Can you find any power switch or power socket/plug around the external or internal units?
Nov 19, 2013 | Cell Phones
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
Air con indoor unit is flashing 6 times out door is off
Please specify the make and model of your unit.
If this is a LG inverter model.
The six flashes of the indoor unit light indicates a CH 06 alarm.
This alarm state indicates that the indoor unit pipe temperature sensor has measured a temperature out of range or the unit is protecting itself from this low temp state. Indoor unit coil temperature to low. Should it have reached a temperature of -5°C for longer that 30sec it will switch the machine off.
It could indicate that the unit refrigerant charge is too low or the sensor has gone out of calibration.
It should measure 5kΩ @ 25°C
Mar 16, 2010 | LG Heating & Cooling
Nov 23, 2009 | Heating & Cooling
Dash board lights on grand voyager flashing when engine on. car would not start so charged bat over night. Then bought a new bat. have changed battery and still happening. Did altinator test lights dipped...
the controls always click when you change the setting as it is electronic, don't panic, but you should ask your ex as he is well up in voyager' s and the back seat not folding down properly!!!!!
Jun 20, 2009 | 2000 Chrysler Grand Voyager
Unable to turn on aircon with remote control and no manaul on button on the air con unit
May 25, 2009 | Heating & Cooling
Problem with reset switch on fedders split unit
This indicates a fault within the unit. Call a service technician and have the system repaired.
I take the time to help you with your problem, so please rate me.
Thankyou Mat
May 18, 2009 | Fedders C36ACD1VF Split System Air...
Heating & Cooling Logo
237 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
