Question about Saws
Hi it just stopped working .the motor didnt give any burning smell.any ideas
  • 86 Answers
Sounds like it could be the switch. Check for continuity at the switch connections on and off.
Posted on Jan 31, 2010
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
I was in the midst of vacuuming with my Dyson Animal when it stopped working. It smelled as though part of the motor burned up (there was hair and string wrapped around the brush so I stopped to remove...
For guidance on clearing any remaining threads or hair from around the brushbar and resetting the machine, please follow the steps shown in the video below. Please note, the brushbar will never rotate when your machine is upright, so make sure you recline it into the vacuuming position before testing it.
This should allow you to restart the brusbar. However, if this doesn't resolve the issue, or if you can still smell burning when the machine is in use, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com/
Mar 05, 2012 | Vacuums
Burning smell from motor
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Aug 27, 2010 | Numatic HVR200P Bagged Canister Vacuum
Kenmore Dryer 76812. The motor sounds like it wants to turn over but it smells like electrical burn and will not start. We cleaned all the lint from the back and around the motor. Any ideas on what we...
It sounds like your motor has gone bad....it will buzz really bad when it is trying to start and cannot...it will also get very hot and give you the burning electrical smell...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Apr 11, 2010 | Dryers
Washing machine filled with water, started agitating, then stopped. smells electrical.
Washing machines are built, sealed so that water or any other liquid that enters into the drums, dryer compartments will be isolated and not penetrate to the electrical system of the unit. There are protections to the motors installed beneath. To give you an idea, a motor mostly installed on it is a split-capacitor single phase motor which is protected by a fuse, thermal overload sensor to prevent burning the winding. A possibilty of electrical burning smells is that, a possibility that the thermal protection of the motor winding didn't open or activate. So that the winding may have been burnt and i'm sure your machine will stop immediately. There is also that timers which are cam driven, there is a strip on the timers and switching between clockwise and counterclockwise rotationion is done here. There is also a possibility that this switches strip may have been warp and burning would have occured due to uneven contact points already, carbonization inside this switches would take place, and your machine would stop. I hope this will help, thanks
Feb 17, 2010 | Kenmore Washing Machines
Heater in 2001 kia spectra stoped working
The burning smell is most likely an issue with the blower motor. These small motors have a hard life and the windings can lose the insulation and short out, hence the burning smell. Another problem can arise if the air intake has filled with leaves and other matter which can be ignited by the fan speed resistor creating the smoke. As this matter rots down, it creates chemicals which can erode the insulation on the motor and cause burning and the eventual failure of the motor. The fan speed resistor is a bank of wirewound or solid state resistors wired across the fan motor which give the individual fan speeds. If these fail then you would lose the fan as well. Search out the fan housing as the resistor is usually fitted into this housing to keep it cool. NEVER turn the fan on if this resistor is out of the housing as it WILL get hot and It can cause a nasty burn..the resistor can have upto 7 wires plugged into it but as to it's exact location, that you will have to find on your own..
Dec 29, 2009 | 2002 Kia Spectra
Frigidaire gallery stackable heavy duty washer stopped spinning and there was a electrical burning smell. what is this?
the problem will be in the motor. most of the time if burning smell comes due to coil burn only please change the motor
Dec 23, 2009 | Washing Machines
Washer stopped during wash cycle, burning smell
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/index.aspx Take a look at what a new motor costs for your machine and go from there. Is may not be a motor is could be a belt or a bearing. I rebiult a washer for less then 50 dollars that one did not need a motor just bearings and a belt. I would take the washer apart so you can get an idea of what went wrong and then look at parts to repair it and decide what to do good luck
May 23, 2009 | Maytag PAV3240A Top Load Washer
Saws Logo
108 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
