Question about HP DesignJet 1050c InkJet Printer
Tryin to get hp 1055cm running. help - HP DesignJet 1050c InkJet Printer
  • Michael Schaffter
    Michael Schaffter May 11, 2010
    What is the problem? Does it turn on?
Error code :0a00100000001 what is this
Hello. The error 0A0010 indicates an air pressure system failure. The APS is located under the ink supply station on the left side of the plotter. The assembly can be ordered from: C6072 60387 Designjet 1050C 1055CM APS Air Pressure System
The service manual with replacement instructions can be downloaded from: HP Designjet 1050C 1055CM repair parts and accessories
Aug 13, 2015 | HP DesignJet 5500PS InkJet Printer
Power supply
The power supply is located in the back of the machine on the left hand side. It is part of the electronics module. It produces 24V, 5V, 3.3V and -15V.
Feb 05, 2014 | HP DesignJet 1055cm InkJet Printer
I just purchased a new computer that has windows 7 and 64 bit and my hp designjet 1055cm plus inkjet printer driver is no longer compatible, Do you know of a driver that will work?
It appears that HP has linked the wrong file to the driver download on the website. I would contact HP and get the correct link so that you can download the driver.
Jul 11, 2011 | HP DesignJet 1055cm plus InkJet Printer
Ink tube leaking in HP designjet 1055cm
No repair parts available except for complete ink tube replacement. Part #C6072-60145. Depending how you get it, $250 to $600 with added labor if you can't do it yourself. Directions included in box.
Nov 30, 2010 | HP DesignJet 1055cm InkJet Printer
HP DesignJet 1055cm Plus system error: 04C300 001F0000.
Its either the EIO card, make sure its seated properly, or the hard disk drive has failed in your plotter. Try running the plotter with out the hard disk drive, it is static sensitive, so make sure your grounded before removing it.
Mar 19, 2010 | HP DesignJet 1050c plus InkJet Printer
Dead hard drive in 1055CM DesignJet Plotter to replace
you can run this printer without an hdd. disconnect the power from the hdd.you may have to disconnect the IDE controller (the small board that connects to the main pca) and disconnect the flat grey cable. this makes your DJ1055CM a DJ1050C it should print okay. you cannot format any hdd to work. you must buy the hdd from HP. if you can find one. good luck and i hope this helped.
May 28, 2009 | HP DesignJet 1055cm InkJet Printer
1055CM WITH BAD BLACK PRINT HEAD DISPLAY
more than likely the slot in your carriage assembly is faulty. try cleaning the contacts on the carriage assembly if that doesn't help, than more than likely you need to replace the carriage assembly and also the trailing cables. if you are going to keep this printer for awhile than you should also replace the carriage belt. if you can find a certified hp repair person, the cost should be around $500-600.
Mar 14, 2009 | HP DesignJet 1055cm InkJet Printer
The HP Designjet 1055cm has 4 ink cartridges, 4 printheads and 4 printhead cleaners. My question is: Will the plotter still work properly if I just install the black ink cartridge along with the printhead...
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
Dec 10, 2008 | HP DesignJet 1055cm InkJet Printer
HP 1055cm printer drivers do not show up on MAC OS9.1 'chooser'
uninstall the Hp printer driver and software.
install the printer software from the CD. download the driver from HP (driver only).
Nov 13, 2008 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
119 people viewed this question
Seeker5211
Seeker5211
