Question about Casio EXILIM Card EX-S770 Digital Camera
Even though the battery fully charges the camera, and it works.--The camera's battery dies out really fast.
It hasn't even been a year since my purchase of Exilim Casio camera. Seriously. I'd return it to Cosco right now; but my mom lost the receit to it. =[ So i can't.
My camera's battery is broken..?
I don't know whats wrong.
I charge it, and its fully charged.
It works fine and i leave it along for like 30minutes--or come to it the next day and its DEAD.
Battery?--its like 0bars out of 3.
Is there a way to fix this?
I'm never buying from casio ever again. Samsung ftw.
  • 374 Answers
Call tech support and tell them that you are having trouble with your battery and they will probably replace it for you free of charge.
Posted on Apr 05, 2008
Why is my laptop unable to run off battery power, even though battery shows fully charged and AC is unplugged
It's time for you to replace your battery.
how old is your laptop? and how do u use it - do u leave it plugged into the wall socket all the time? It's common for batteries to die out after a couple of years. however, if the computer overheats or if you leave it plugged in all the time, it's life cycle will decrease. Charge - discharge cycles. That's how you are suposed to do it.
Jul 17, 2014 | Lenovo IdeaPad U550 Notebook
The battery is charged, but there is no turnover, just a continuous clicking sound.
sometimes a battery will go bad even though it shows 12 volts it hasn't got the cranking amps to fully engage the starter. Try another battery and if you still have the problem you will need to replace or rebuild the starter
Sep 21, 2011 | Honda Shadow Spirit 750 Motorcycles
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully...
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
May 22, 2011 | Olympus Stylus / mju 1040 Digital Camera
My razor appears to have died even though the LED
Usually the batteries last only a few years before needing replacement. Rechargeable batteries are good for only so many cycles so you've done well to go 8 years. You can replace the batteries if you're handy with a soldering iron - I've done it many times. However, with 8 years on the clock you'll probably want to replace the blades too. The batteries are about $10 for the pair (AA rechargeables with solder tabs) and the blade set is about $30 so you're approaching the cost of a new shaver already. Here's a link - you'll need two.
http://www.zbattery.com/NiCad-AA-1000mAh-Rechargeable-Battery-with-Solder-Tabs
Apr 18, 2010 | Norelco SmartTouch 9160XL Electric Shaver
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Will not turn on
take the battery out for a few mins, press and hold power button, re-insert battery, worked for me????
Oct 07, 2008 | Jazz DV-179 Digital Camera
Canon 400d will not switch on
it might be a problem with the battery connectors.
They might not touch the battery well.
another reason, it might be the battery is dead or the power button is not working.
Aug 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Camera Draining Battery
Lachuaeyes,
I have a different model of Olympus and I read that you did not always have this problem and you already have replaced the battery so an old battery is not likely the issue. I suspect you might have something that is draining that was not set in the past. I keep my batteries longer by not using flash most of the time. Is there someone new using the camera that perhaps leaves it on longer than you do after finishing, perhaps uses flash longer? Is there a setting for auto shutdown that has been changed to not turn off as fast as it used to? If none of these I wonder if the flash is requiring more energy than in the past.
Could you tell me if the battery is draining even if you don't use it or is it only if you are using it does it drain faster.
Another possibility is that the charger is not charging so well as it used to but I suspect you leave it in long enough and more.
If you have the ability to check the output voltage of the charger with a multimeter you would be sure it is really putting out enough volts to charge fully.
Please let me know if you have further questions.
HarryF
Dec 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Camcorder problem
you need a new battery
Nov 06, 2007 | JVC COMPACT VHS-C CAMCORDER
Casio EXILIM  Card EX-S770 Digital Camera Logo
65 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
