Hi my pc keep freezing i have good memory and good hardrive what is it
    President:
  • 1,871 Answers
Did you check the fan ? if it's good then try to repair the operation system .
good luck
Posted on Jan 31, 2010
  • Fathi Elmahdi
    Fathi Elmahdi Jan 31, 2010
    or scan your system for viruses !
EMachines Recovery Discs
Hi Sandysue, As I understand your problem, 1. The error could be caused by: memory, video, hardrive or drivers; 2. Windows by asking you to run CHKDSK /F has detected a possible problem with your harddrive; 3. It is possible that the reason you cannot go to DOS mode is because your harddrive is formatted in NTFS and not FAT332. There are a couple of ways on how to go about this but all would require that you have access to second PC: 1. Run a third party software (BartPE) that you will have to boot from your CD Drive or USB and run a disk checking utility; 2. Remove your hardrive and install it as a secondary master in the 2nd PC and run chkdsk or scandisk; 3. Remove your hardrive and install it in an external HD enclosure and connect using USB to the 2nd PC and run chkdsk or scandisk; 4. Remove your hardrive and install it either USB or as secondary master to the 2nd PC. Copy all your important files to the 2nd PC, and repartition/reformat. Reinstall to the eMachine and reinstall Windows. There is a possibility that even if you were able to run CHKDSK or Scandisk eventually your best bet would still be #4. If you have gained access to the inside of your eMachine PC, it would also be a good idea to remove/reinsert any cards and the memory stick(s). A little housekeeping would also be nice. I hope that this be of some help and pls post again how things turn up or if you need further information. Goodluck and kind regards.
Jul 31, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
My desktop is getting stuck so many times. It shows bluescreen and physical memory dump even when i tried to install new copy of windows. the error is technical error stop : 0X0000007A(0XCO7B9FB8,...
It can be a few things but usually the atapi.sys file is corrupt. If you can boot into your desktop, open the "run" box and type in "cmd". In that box type: sfc /scannow and press enter. There is a space between sfc and /scannow. You will be asked to put your Windows CD in the CD drive.
When did this problem begin? Have you installed a new harddrive recently? Have you installed new memory recently? Remove and re-insert the hardrive cables. Remove and re-insert the memory. Be careful about electro-static discharge. Sometimes just doing that will fix a bad connection.
Sometimes this error is caused by bad memory. You can download Memtest86 here: http://www.memtest.org/ Grab the prebuilt ISO.zip After downloading the file right click it and select "extract all" Use Img Burn http://www.imgburn.com/index.php?act=download to write the ISO to a CD. Keep the CD in the drive and reboot.
Also, there could be a problem with the hardrive. if you know the harddrive manufacturer you can usually go to their website and download their hardrive diagnostic software.
Sometimes erasing the hardrive (absolute last resort) will solve these kind of errors. Just be aware that you will lose ALL of your data and it mat not solve the problem. Darik's Boot and Nuke works good for that: http://www.dban.org/
Feb 09, 2012 | Computers & Internet
My game keeps freezing at the same spot
Hi, If it keeps freezing it could be that you need more memory to run your game or more space on HDD. Good luck.
Jul 02, 2011 | Disney Interactive Pirates of the...
I have a sony vgn-fe780g laptop computer. I cannot load windows. The memory test good with windiag. The hardrive tests good. The computer hangs at loading the mup.sys file if when starting in safe mode. I...
Make sure your installation CD is ok by testing it in another system. You can use utilities in programs like Nero to scan the disk and make sure there are no read errors.
Let me know if this is of any use.
Best wishes,
Graemevm
Mar 05, 2010 | Sony VAIO VGN-FE780G Notebook
My laptop freezes when I use USB ports
dell insprion 1525 revision A13 bios password crack
Feb 03, 2010 | Computers & Internet
Keeps freezing up
You may consider a good virus software like Mcaffee and spyware remover. If those don't work then possly up to and leading to reformattting the PC...
Nov 03, 2009 | Acer Aspire One PC Notebook
Gateway laptop keeps freezing every few minutes
I had the same problem with my gateway laptop. try reinstalling windows xp pro instead of vista if this does not work replace your hardrive.
Nov 02, 2008 | Computers & Internet
Problems with control Panel dell inspiron6400
Hi, A common glitch in Vista. Here's a link to a forum with several work around. solutions and explanations. http://www.tomshardware.com/forum/236390-44-vista-control-panel-issue Hope this be of some help/idea. Post back how things turns up or should you need additional information. Good luck and kind regards.
Sep 30, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
David Payne
David Payne
