Question about ViewSonic VG930m LCD Monitor
ViewSonic VG930m. Just being curious, I went to where you change resolution and saw something about the Intel Graphics. I clicked on Color Management, and the screen suddenly looked like a REAL window screen had been laid on top and I couldnt see anything or make anything out. I unplugged the monitor from the wall and computer and rebooted the pc. I can at least see stuff again, but now everything has a YELLOWISH GREEN tint. I messed with the settings and cant get it to change back. I checked the driver for updates and it says it has the latest. Is there anything I can do to make it go back to normal and bright like it was before I messed with it? Thanks! Notageek
3 Suggested Answers
  • 152 Answers
SOURCE: How do you remove the outer case on Viewsonic VG930M-3 LCD
kauffman014, As far as opening the monitor up you may want to visit YOUTUBE and search for lcd monitor repair/ disassembling monitor/ or something like that. I did see a 9-11 min video there that was fairly good on un-snapping the rear cover from the front bezel of what I think was a DELL unit. Also visit electronicrepairguide.com run by a jestine yong. don't pay any attention to his ad to purchase repair course in lcd/fpd servicing!! only look at the pic's of the insides of lcd monitors and the power supply boards/inverter boards. On gateway's, and dell monitors the pedestal must be unscrewed from the rear cover first. The pedestal is really screwed down to the steel FPD chassis that covers the circuit boards and provides a ridgid mounting surface for the unit as a whole. Work on a flat surface with screen facing down on a blanket or lots of newspaper to prevent maring of the FPD!
There should be some phillips screws that fasten the steel shield to the left/right sides of the FPD frame. Once you get down to looking at the Switch-Mode-Power-Supply (smps) board look for large filter capacitors (electrolytic polarized aluminum can) that have the tops of them bulging upward as compared to normal ones that are flat. You will also need to inspect the bottom (solder side) of the board where all the leads of the components from the top side are soldered. You are looking for very thin hairline 'thermal' and or 'vibration' circular FRACTURES around the leads of the larger and bulkier (heavy) components. Yeah...use a big magnifying glass or better yet a 10x or 20x inspection microscope. One last thing, I highly recomend taking digital pic's as you disassemble the unit so it can be put together again without leftover parts. hope this info helps you out. Get back to me if you find out anything. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Posted on Mar 28, 2009
  • 117 Answers
SOURCE: how to disable the resolution notice
Use your monitor buttons to look for Resolution Notice and turn it off.
To disable the notice on ViewSonic 23" LCD Monitor , use the buttons on the
front of the montior to do the following:
* Press #1 button
* Use down arrow to highlight Setup Menu and press #2 button
* Use down arrow to highlight Resolution notice and press #2 button
* Select Disable and exit!!
To disable the notice on NEC LCD 1765 monitor
* Press button #5 on the monitor
* Scroll up and down the menu list with Montior Button #4 and then select
with Monitor Button #5. Go to "Advanced menu" set the Resolution notice to
OFF.
Posted on Nov 02, 2009
Move screen to left
If you are talking about resolution and you are with Intel , there is a program called Intel Graphics Options / Properties. Simply right click your desktop and click the Graphics Options and there will be options to change your resolution and aspect ratio.
Good luck :)
Oct 13, 2015 | Acer Aspire Computers & Internet
Battle Realms: Winter Of The Wolf Resolution cannot play in widescreen Intel graphic and AMD RAEDON graphic
If you see black labels at both sides of screen you have to change screen properties in your Graphics Cards's main panel, I mean open yout Intel's main panel, go to Screen or Resolution section or tab, then search through an option that might be like "Image Scale" or something like that and change it to: keep scale
Important note: if you see it in grey color, you might first change your resolution to a lower one, then you would see it enabled or with more options :)
Feb 13, 2013 | Ubi Soft Entertainment Battle Realms:...
I am using VA1903wm LCD monitor from Viewsonic. It worked well at its non standard resolution of 1440*900 when used with Windows Vista. i had to upgrade to Windows 7 Enterprise edition and this resolution...
Update your graphics card drivers to the newest ones available. That is typically caused by having the default windows driver for your graphics card. If it is a Nvidia gpu get the drivers from them, itf its an ATI/AMD get them from AMD Game. If it is neither of those Intel does some graphic cards, if its not an Intel one go to the computer manufacturers website and find your model to get drivers for it.
May 17, 2011 | ViewSonic VA1930WM LCD Monitor
I get the following error "OUT OF RANGE" are there any steps to resolve this issue?
You need to set your PC video resolution to 1280x1024 for this monitor native resoluiton. Start up the the PC in safemode (hit f8 while booting up), set the PC resolution to 640 x 480, reboot, then reset the resolution to 1280x1024.
Feb 18, 2010 | ViewSonic VG930m LCD Monitor
How can I change the resolution from 1280 x 800? This is the highest possible according to the display setttings. I have removed the generic pNp monitor. I am running Vista Business. The display adapter is...
Graphics Unable to use the native resolution, such as 1920x1080, 1680x1050 and 1440x900 circuit388.gif Symptom(s):
On some displays, users may be unable to use the native resolution when using Intel® chipset graphics. Resolutions such as 1920x1080, 1680x1050, and 1440x900 are not available in graphics properties.
Cause:
The display's EDID is not read properly when connected to some digital flat panel displays. Display devices describe its capabilities by sending EDID (Extended Display Information Data) to the computer.
Solution:
Intel has released a graphics driver to specifically address this issue; however, there may be side effects to this solution such as longer than normal resume times from standby. This solution will only work with external displays such as DFP displays connected to the computer's VGA port. This driver is not designed to address issues with a notebook's built-in display (Local Flat Panel) or with TV’s connected to the system. This driver is provided as is. Intel has not tested, and does not guarantee, the operation of the driver for this purpose.
For the desktop and Mobile Intel® 945 Express Chipset Families:
If you have a computer that has the Intel® 945G or 945GV Express Chipset or the Mobile Intel® 940GML, 943MGL, 945GM, or 945GMS Express Chipset, click here for drivers that resolve this issue.
For the Intel® 3 Series Express Chipset Families and the Mobile Intel® 965 Express Chipset Family:
If you have a computer that has the Intel® G31, G33, G35, Q33, Q35 Express Chipset or the Mobile Intel® 965 Express Chipset, click here for drivers that resolve this issue.
For the Intel® 4 Series Express Chipset Families:
If you have a computer that has the Intel® G41, G43, or G45 Express Chipset or the Mobile Intel® GL40, GM45, or GS45 Express Chipset, click here for drivers that resolve this issue.
For the desktop Intel® 946 and 965 Express Chipset Families:
If you have a computer that has the Intel® 946GZ, G965, Q963, or Q965 Express Chipset, click here for drivers that resolve this issue.
How to identify your Intel® graphics controller
How to install the graphics driver
I cannot select a larger display mode (resolution, refresh rate, or color settings). How do I resolve this issue?
Error: "The driver being installed is not validated for this computer..."
Operating System:
Windows XP Professional x64 Edition*, Windows Vista 64*, Windows Vista*, Windows Vista 32*, Windows 7*, Windows 7, 32-bit*, Windows 7, 64-bit*, Windows 7 Enterprise, 32-bit version*, Windows 7 Enterprise, 64-bit version*, Windows 7 Home Basic, 32-bit version*, Windows 7 Home Basic, 64-bit version*, Windows 7 Home Premium, 32-bit version*, Windows 7 Home Premium, 64-bit version*, Windows 7 Professional, 32-bit version*, Windows 7 Professional, 64-bit version*, Windows 7 Ultimate, 32-bit version*, Windows 7 Ultimate, 64-bit version*, Windows XP Professional*, Windows XP Home Edition*, Windows XP Tablet PC Edition*, Windows XP Media Center Edition*
This applies to: Intel® 3 Series Chipsets
Intel® 4 Series Chipset
Intel® 82945G Express Chipset
Intel® 82946GZ Graphics Controller
Intel® 82G965 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q963 Graphics and Memory Controller Hub (GMCH)
Intel® 82Q965 Graphics and Memory Controller Hub (GMCH)
Intel® 945 Express Chipset Family
Intel® 946 Express Chipset Family
Intel® G31 Express Chipset
Intel® G33 Express Chipset
Intel® G35 Express Chipset
Intel® G41 Express Chipset
Intel® G43 Express Chipset
Intel® G45 Express Chipset
Intel® Q33 Express Chipset
Intel® Q35 Express Chipset
Intel® Q43 Express Chipset
Intel® Q45 Express Chipset
Mobile Intel® 4 Series Express Chipset Family
Mobile Intel® 945 Express Chipset Family
Mobile Intel® 945GM Express Chipset Family
Dec 06, 2009 | Acer TravelMate 5730-6204 Notebook
How to disable the resolution notice on VG930m
* Press #1 button
OFF.
Nov 02, 2009 | ViewSonic Computers & Internet
Nvidia geforce 9400gt 1gb card problem
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
May 13, 2009 | Computers & Internet
Viewsonic vx2245wm
You need to chk graphics settings in NVidia control center and change resolution until it looks right
Mar 06, 2017 | ViewSonic VX2235wm LCD Monitor
VG930M-3 Taking base of this monitor...
After a chat with a Viewsonic tech and pulling out a lot of screws, this is what I discovered you have to do;
Find a secure place to turn your VG930M upside down, like on an armchair.
Undo the central screw on the base and remove the rotating black plastic plate.  Make sure you know which way it goes back on again.
Remove all the screws on the metal plate, something like eight around the circumference and another two which attach to the LCD support column. (You were never just going to pull that base off!).
Now for the tricky bit! The support column has two extensions that extend down into the base and click into position.  You have to get a flat blade screwdriver and push one of them towards the centre while trying to lift the base just a little away from the support column, so that it is unclipped.
Then you have to do the same with the other extension, while lifting the base a little. The base should now pop off.
Not as straight forward as some screens but achievable!
Good Luck!
Aug 25, 2008 | ViewSonic VP920b 19" LCD Monitor
ViewSonic VA2216w cannot get resolution 1680 - 1050
Dont change the screen resolution by going to computer resolution screen or the settings screen.
Open the NVIDIA graphics utility or display utility and change the settings from there as all the controls regarding the screen resolution and the color effect are now handled by NVIDIA...
Feb 21, 2008 | Computers & Internet
ViewSonic VG930m LCD Monitor Logo
80 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
