Question about Magellan eXplorist 500 GPS Receiver
Explorist 500LE with firmware 2.17 (lost)
I possess a 500LE that is almost dead. It had the famous firmware 2.17, and I tried to use a solution suggested by rhamphorinkx in order to change it: I inserted the files USB0002.CMD and USB0002.DAT of the firmware 1.61 in the directory USBTRANS of the GPS.
The loading of the new firmware didn't go to end correctly.
Now my 500 is lacking of firmware, it is not able to use the secret commands, and surely it wouldn't be disposed to accept a firmware different from the 2.17 one (by the way I do not possess this firmware).
I am able to introduce in it data through the serial port (through the USB port it's no more detected).
I possess another identical 500LE with firmware 2.17.
Do you know a way to unload the firmware from this second 500LE?
In particular, for a loading through the serial port, I think it would be better to have it in .hex format, but perhaps I should be able to do something also with the files USB0002.CMD and USB0002.DAT of the 2.17 version . Have you any suggestions at regard?
Thx alot, take care
Alberto
  • 3 more comments
  • pippokid
    pippokid Feb 18, 2008
    I only saw the one relating to the pression on the right bottom portion of the display + compression of the power button. I didn't yet try it.
    Do other ways exist?
  • pippokid
    At the above link I can download the 2.03 US version or the 2.57 EU version of the firmware. But the 500s in which the 2.17 version is installed do not accept any different version. If you look at this also in the internet you can see that the 2.17 verson cannot be replaced anyhow.
  • pippokid
    my 500le is not able to be turned on. the only life sign is going in data transfer mode with secret commands
  • pippokid
    the GPS is not able to accept secret codes. the fact of not having the firmware prevents it from having this function. it can communicate with the PC only through the serial port; apart this, it cannot turn on
  • pippokid
    pippokid Feb 19, 2008
    it accepts only the secret command LIGHT + ENTER + RWR, not the numeric secret commands (doesnn't go to the window with the two zeros
    Brigadier General:
  • 3,614 Answers
Hi, here's the link where you can find your firmware and maps & software, i copy and paste the link below.
Magellan Explorist 500LE
enjoy.
Posted on Feb 18, 2008
  • 1 more comment
  • micromaster
    micromaster Feb 18, 2008
    manuals also included there.
    Regards
  • micromaster
    MapSend Streets & Destinations was designed for use with Magellan Meridian and SporTrak series GPS receivers. These products use a different central processor. They do however work with MapSend DirectRoute software.
  • micromaster
    Try Press ? hold the power upto 5sec. then release.
    Hope it works for you.
  • 689 Answers
Have you tried to reset to the factory default? I will be checking some solution for it.
  • ExpressFiX
    ExpressFiX Feb 18, 2008
    Setting to Factory Defaults
    • Press MENU
    • Use the Arrow joystick and highlight "Preferences"
    • Press ENTER
    • Use the Arrow Joystick and highlight "Reset Defaults"
    • Press ENTER
    • Use the joystick and Highlight "All"
    • When Confirm prompts highlight YES
    • Press ENTER
  • ExpressFiX
    have you tried secret code 22?
My Explorist 210 does not connect with any computer. What can I do.
What is happening is your computers are not recognizing your unit. Means you have to update unit via the registered site for updates.
first Perform a hardware reset to return the minor settings of the GPS to the original condition. Press the small "Reset" button on the side of the unit for several seconds until it powers off and powers back on.
If that doesn't solve the problem, then it means you will have to perform a firmware upgrade to put the GPS back in order.
Download and install the Content Manager software available for free from the Magellan support website. Connect your GPS to your computer with a USB cable, and the software will automatically search for firmware updates for your GPS.
Here is support to copy and paste in your browser for Magellan.
http://support.magellangps.com/support/index.php Thanks Mike
Oct 05, 2011 | Magellan eXplorist 210 GPS Receiver
Cant not get watereays on explorist 500 in canada
You can try to update your GPS firmware.
Before you update your Magellan eXplorist 500 firmware or install a custom basemap, Magellan recommends that you backup all of your GPS data.
Click here to download the firmware update (Version 2.57)
Connect your Magellan GPS unit via the USB drive.
Double-click on the update file to begin the installation process.
Follow the on-screen instructions .
Jun 17, 2011 | Magellan GPS
Hi Guys: On turning on my explorist 400 a message appears. UNIT CURRENTLEY CONTAINS NO MAPS! INITIATING MAP UPLOAD This message wont go away, and all buttons refuse to work. The only way I can turn it off...
Jeff, I had the same problem with my explorist 500. Your unit lost the "BASEMAP.MGI " file. You will need to get a copy of that file. Then install it.
Try this site http://imhz.com/2006/05/my-explorist-is-screwed.html
(I would recomend all explorist GPS owners copy and save that file and store it in a safe place. I have mine on a thumb drive).
Dec 05, 2009 | Magellan eXplorist 400 GPS Receiver
Screen is out
A black screen, actually purple, means that a firmware upgrade was unsuccessful. You can try to fix it by reloading the firmware, but you are most likely not going to be successful using the USB 'binary'firmware that is available.
There is some 'text' HEX firmware available on the yahoo Explorist user group. To use it though, with your USB cable, you will need to make a small circuit with 1 chip. That site shows how to do it. I am in the process of doing that for an Explorist 400 for a friend. Others have said this is the only to recover such a lost GPS. I'll keep you informed of my success when it happens. I'll probably be sending the circuit/cable I build along to other friends but could possibly fix your for you if you like.
Nov 25, 2008 | Magellan eXplorist 300 GPS Receiver
CAN NOT GET MAP ON GPS MAGELLAN EXPLORIST 210
try updating the firmware from the magellan website that fixed mine.
Oct 29, 2008 | Magellan eXplorist 210 GPS Receiver
No base map message
Go to: http://www.magellangps.com/support/product.asp?prodid=1114
Or, if this doesn´t work, go to www.magellangps.com, click on "support", click on "legacy products" (left) and click on "eXplorist 210 Europe" (do NOT click on "eXplorist 210 North America")
On this page click under Updates/Upgrades on "version 2.57", and follow the instructions.
After you have installed the firmware you will have the basemap and some new windows on the GPS. Good luck and enjoy!
Jun 29, 2008 | Magellan eXplorist 210 GPS Receiver
Explorist 210 No maps loaded
You will have to register your GPS, register with a European country, and it will work out fine.
Jun 28, 2008 | Magellan eXplorist 210 GPS Receiver
Explorist 210 no base map
I solved this problem by gonig to the secret menu by holding the nav + power. I entered the value # 95 in the menu. This will let you format the memory area in the unit then I down loaded the latest firmware update from magellan.com and installed it on the
unit.I had already made a copy of the files on the unit in my hard drive so i copied the files back to my unit so that i did not loose anything important like poi's and geocaches etc...
PS when I did the firmware up date the base map must have been restored.
Jun 27, 2008 | Magellan eXplorist 210 GPS Receiver
No map
Install the firmware again:
On this page click under Updates/Upgrades on "version 2.57", and follow the instructions. You will have to register your GPS, register it under a European country.
Apr 13, 2008 | Magellan eXplorist 210 GPS Receiver
Lcd source
Try looking on ebay for a new screen. Or contact the manufacturer for instructions!
Aug 15, 2007 | Magellan eXplorist 500 GPS Receiver
Magellan eXplorist 500 GPS Receiver Logo
647 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
