I HAVE A SAMSUNG HL-R6768W TV THAT WORKS GREAT UNTIL IT WARMS UP, THEN THE PICTURE IS TOTALLY GARBLED. I SUSPECT A COOLING PROBLEM, ANY THOUGHTS?
  • 1 more comment
  • gary300 Jan 31, 2010
    Are the IC's something that are plug in replacement? and, if so, how do I go about it?
    I am NOT an electronics wizard, I can pull plug in parts and replace them, but to identify a burned out transistor is probably beyond my pay grade
  • gary300 Feb 01, 2010
    This answer is what I was looking for. Clear and concise. I have not fully followed the specified steps yet, but the answer is stated in a way that I can understand. Thanks
  • 5,138 Answers
TV has 3 Fans Lamp Fan,Ballast Fan and DMD module Fan, Look on Far Left side of TV chassis this is where your power supply board is Look for Bad or Vented Capacitors 1000uf 10v- 2200uf 16v -3300uf 10v if you see any that are vented on top or puffed up on top they are bad.
CK the DMD FAN if it stops running it is defective and that could cause problem also. For Module/Boards Call Encompass Parts Distrubtion
1-800-638-3328 For- Lamp and minor parts Call Mats Electronics
1-800-628-1118
Posted on Feb 01, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Heat is the number one enemy of electronics, and these sets operate hot. This problem is caused by the power supply being overloaded. This is often caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. This model of TV has over 3,000 parts which include millions of transistors inside the integrated circuits. Over time the capacitors will change value, leak and become defective. Resistors will change value and burn. This will cause other components to become defective. This can has a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 31, 2010
  • Rylee Smith
    Rylee Smith Jan 31, 2010
    You have to open the back off the TV and blow the dust off then check for the power board for blown components and the convergence board for replacing the ICs. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Then as I said earlier its always better to get this done by a authorized repair center, and you'll be charged around $200-$300 including labor. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
How do I reset lamp time in Samsung DLP TV- Model HL-R6768W?
http://www.fixyourdlp.com/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter-or-lamp-timer/
Try this link for details.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 23, 2014 | Televison & Video
How do I change the lamp time after replacing my lamp
In the menu under set up there should be a sub category for that.
Apr 20, 2014 | Euro-Pro UV209 Upright Vacuum
Buzzing noise in my HL-R5067W
you might be right. Color wheel can make this noise.
Jun 08, 2012 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 56" tv,distorted picture
if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
if it's a yes?
so its probably the light engine. you need to change it!
try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
the price is more or less depends on your TV model... $279.00
Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
Rattling sound from the Samsung DLP TV
Your Color Wheel is bad and needs to be replaced by a trained Samsung tech. There are adjustments that must be made after the color wheel is replaced. Part# is BP96-01579A
Jul 15, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-R6768W started making squeal noise from rear of TV. At same time lost picture and will not come back on. Sound is ok and you can hear light trying to turn on. Can fan motor not working correctly...
Look at the fan and verify its comming from the fan and not the power supply unit, you can clean the fan or replace it, but yes the fan would be likly the problem. Make sure you double check the power supply unit and clean if its needed,
Rulds2008
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-S5086
Vertical problem and most likely a bad capacitor in the Vetical out circuit or IC.
Nov 24, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
