Washing machine stopping mid cycle
I have an AMICA washing machine which keeps stopping mid cycle. It flashes alternatively been READY and RUN. I have to put the program back to 0 and then reselect the program that is running and it starts again fine. I have this probem before and it was a build up of water in the base of the machine which was kicking off the water level trip switch.. mopping up the water fixed this but it is happening now and there is no water build up in the base.. any ideas?
  • 100 Answers
SOURCE: Washing machine won't drain
It sounds like you may have some bad contacts in the timer or you may have a bad lid switch which will not allow it to go into a spin during the rinse cycles or the final spin.
Posted on Oct 30, 2007
vest6
  • 196 Answers
SOURCE: WASHING MACHINE OVERFILLING
Suspecting the water level switch is the first step since this device controls starting operations. There is also a possiblity that the water level pressure hose has come off the tub. Make sure this plastic line is attached before replacing the level switch.
Posted on Jan 14, 2008
jason0110
  • 66 Answers
SOURCE: My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Posted on Jun 14, 2008
  • 44 Answers
SOURCE: Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Posted on Jul 30, 2009
MakeupWizard
  • 39 Answers
SOURCE: washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Posted on Apr 22, 2010
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Doesn't work. Why does it stop mid-cycle?
    washing machine stopped mid cycle, won't drain : DIY - Reddit
    https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
    RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
    Troubleshoot - washer stops mid cycle, won't drain or spin ...
    ? 1:58
    https://www.youtube.com/watch?v=6Gc0ZgLD6a4
    Jun 20, 2012 - Uploaded by searspartsdirect
    Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
    Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
    Why does my washer stop half way through cycle - Ken
    Dec 18, 2015 | Washing Machines
    Stop in mid cycle
    washing machine hotpoint hvl211 stops in mid cycle and wouldn't take the conditioner This video will show you how to keep your soap draw clear and how to service the parts
    Please remember to subscribe to our YouTube channel for all appliance tutorials
    a 4 THUMBS rating is appreciated for answering your FREE question.
    And don't forget to like us on facebook
    Aug 03, 2012 | Washing Machines
    Amica Mother board has been stopped working. its not spinning.
    If the board is malfunctioning, your only source of action is to replace it.
    May 24, 2012 | Washing Machines
    Amica washing machine power stop whats the prolbem
    Hi, my Amica AWCT washing machine has no power. I have checked the external source, together with the fuse in the plug that is all fine. Any suggestions would be appreciated! thanks Tam
    Feb 02, 2012 | Washing Machines
    Stops mid cycle. Light flashes, cant get it to move on so have to start all over again
    Hi there.
    I have the same problem with my machine. Whatever program I select, the machine runs fine until it reaches 54 mins of the cycle remaining. To overcome the problem just to select a cycle that will not stop mid cycle, select a program which is less than 54 mins. I think the 40 degrees and quick wash select is the one to run with. The cycle is 45 mins, obviously less that 54 mins. The LED timer will display the cycle time. No problems with this cycle whatsoever. Not the total solution, but at least you're able to complete a cycle. After it's completed, I also run the spin program at 1200rpm. I hope this helps.
    Regards, Ian.
    Nov 22, 2010 | AEG Lavamat 72640 Front Load Washer
    My Kenmore 110-46462501 washing machine stopped mid-cycle
    Can you hear the pump running? It might be plugged or not running
    Oct 20, 2017 | Kenmore HE2 Plus Front Load Washer
    Ariston A1635 Margherita Control knob spinning
    According to the instruction book - it appears the machine has been stopped mid cycle then re-started.
    Switch machine off, turn control knob to a solid circle symbol (they are after every set cycle). Switch machine back on and lights will flash and program is reset. You can then select wash cycle as normal.
    Jan 22, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
    Machine keeps stopping
    i bought a new washing machine but thanks anyway
    Jan 22, 2009 | Creda W100FW Front Load Washer
    Washing Machines Logo
    66 people viewed this question
    Top Washing Machines Experts
