Question about Abacus Flight Deck 5 Expansion Pack for Windows
Unable to find fsx in windows registery unable to complete flight deck5 setup
  • 122 Answers
Have you searched the registry using CTRL + F and typing in FSX or Microsoft? This should find all entries. If not, then FSX is not installed properly and you need to uninstall FSX, reboot and re-install. Good luck with it.
Posted on Jul 13, 2010
I had to reload flight simulator fsx and 5 time it went to the end and I received an error message! and did not complete. Can you help?
Each time you are installing FSX installation is leaving behind files. Get a good quality registry cleaning program. Uninstall FSX, reboot, use the reg cleaner, then reboot, then re-install and you will be okay
Mar 24, 2010 | Microsoft Flight Simulator X for Windows
I have Microsoft Flight Simulator X and a Satek X52 flight control, however I have problems with the throttle on all aircraft. I have to use the F-4 key - can you help?
You need to assign the throttle function correctly WITHIN FSX settings area itself. Also calibrate the joystick in windows first. If you are not familiar with assigning FSX functions to your joystick, check the Learning Center section within FSX for step-by-step details.
Feb 24, 2010 | Microsoft Flight Simulator X for Windows
FSX Icon does not show on the desk top
Go to the FSX directory, find FSX.exe, right-click it with the mouse, and whilst holding the right button down, drag to your desktop and release the button. Choose "create shortcut here" from the fly-out menu. This will sort it. Good luck
Nov 17, 2009 | Microsoft Flight Simulator X for Windows
Microsoft fsx when reinstalling comes with an error 1722 followed by an error 1603
OK. This is what you need to do.
1. Uninstall FSX completely the reboot.
2. Press CTRL + F and type in the search box "FSX"
3 Each entry that comes up should be deleted from the registry. Press F3 to continue searching. When no more appear, reboot and re-install ensuring that FSX CD's are clean. If you are not confident clearing registry entries, get a reputable registry cleaning program, but use it after you have uninstalled FSX. Good luck
Nov 07, 2009 | Microsoft Flight Simulator X for Windows
FSX Not responding. Uninstalled every application and add-on. Re-installed FSX, but still will not respond
This is a registry issue. Get yourself a good registry cleaning program, uninstall FSX, reboot the PC. Run teh reg cleaner, then reboot. Now you will be able to install FSX okay. Good luck
Oct 20, 2009 | Microsoft Flight Simulator X for Windows
When i try to load a flight plan and click save it closes fsx
Where are you getting the FP from? If it is a third party software, the resulting Flight Plan must have a .pln extension to the file. If it is a FP from within FSX, you set up the plan, then tell it to load it, then you can save it okay.
Sep 24, 2009 | Microsoft Flight Simulator X for Windows
Flight Sim X fails to load at statup
Check your video card and its drivers are up to date and not corrupted. Might be worth downloading new drivers. Basically after the menu screen the sim enters Direct3D mode and if there is a video driver problem, this is where it will pop up and start causing problems.
Jan 20, 2009 | Microsoft Flight Simulator X for Windows
Direct x problem for fsx
Get rid of the pirated version, which is completely illegal and buy a proper copy and you will have no problem. If you try to register this software or update it, Microsoft will see it is a pirated copy and probably contact you with a law suit.
Jan 10, 2009 | Microsoft Flight Simulator X for Windows
MS FSX -view keeps switching from cockpit to spot view
The most likely problem here is that you have multiple assignments for the view change command set to multiple controllers hooked up to the system. They are conflicting with each other causing random view changes.
Firstly, go into Windows Control Panel and to Game Controllers. Remove any controllers listed in that box that are not currently connected or being used in your flight simulator.
Next, go into FSX, into the control assignments section...
Go through each controller in the drop down box (in the button/keys tab) and ensure only one controller has the assignment for view changes assigned.
Nov 23, 2008 | Saitek Pro Flight Yoke System Flight...
Abacus Flight Deck 5 Expansion Pack for Windows Logo
314 people viewed this question
Top Abacus Video Game Consoles & Games Experts
James Wishart
Are you an Abacus Video Game Console and Game Expert? Answer questions, earn points and help others
