Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
MFC-240C 'Init unable AF' being shown what does this mean ?what can we do? Thanks Angelique
  • Anonymous Apr 17, 2008
    I have this problem ' mfc 240c See troubleshooting and routine maintenance chapter in User´s Guide_ Please help me!!! my mail is please i need your help
  • 832 Answers
You have to reconnect the scannerflatcable to the main circuit board.
Open the scanner top as when a paperjam had occured. Remove the "Z" lookinglike plastic cover near the middle running to the right side which hides the flatcable. Simply stick the flatcable into the mainboard, close the cover
again and close the scanner top.
Posted on Feb 18, 2008
It dosnt solve my problem...
Posted on Feb 22, 2008
Brother mfc 240c machine error 40
Unplug the machine from the AC outlet and if possible cool the room where the machine is located.Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother Multi-Function Center MFC-240C...
Unable to Init. AF in brother mfc 64900 cw printer
initial error AF, check the scanner flex cable or any cable, either they are not fix or not intalled properly..
Jan 28, 2014 | Brother MFC-5440CN All-In-One InkJet...
Mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
It says init unable 40 or init unable 43. it
Brother warranties for one year, you can call
1-800-276-7746 and they can give you the nearest service center.
Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
Scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
May 10, 2009 | Office Equipment & Supplies
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 26, 2009 | Brother MFC 240C All-In-One InkJet Printer
Unable to inif 4f
please be a little clearer about your problem. brother tech
Nov 03, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-240C init. unable AF error message
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Dec 12, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
270 people viewed this question
James Cagle
James Cagle
Jim Keysor
