Question about HP Compaq Pavilion dv6110us Notebook
I get a hardware device already being installed error when I try to install anything does this mean my usb port is bad?
  • 62 Answers
No, may be it is already installed but you didn't notice it, if this problem still, reinstall your operating system.
Posted on Jan 31, 2010
Wi fi not working error 10
Code ten means there was some kind of hardware error that prevents windows from loading the driver.
If it is a USB Wireless device, make sure you are not using a hub. Plug it into a full power USB port.
Try a different port. If it is a built in card, such as PCI or MPCI-E, you will likely need to replace the device. Sometimes you can get a code ten from lack of resources. Try dissabling some hardware you do not need in the device manager. Items such as serial ports etc. (Anything you don't use)
Mar 25, 2011 | Computers & Internet
UsB port malfunction message
Check the all functions installed properly.
Go to these steps:
Start > Control Panel >System > Hardware Tab > Device Manager
If errors on USB port presents ,then reinstall intel chip set software,it can install either by the cd that came with your board or that is must downloaded from the intel center.
If these all steps are already given then do following:
Enter bios setup by pressing F2.
Go to Advanced >USB configuration
Set USB 2.0 to enabled
Exit and save changes.
Dec 09, 2009 | Intel DG965RY Motherboard
Keeps saying no video capture hardware please help
Good day Sir/maam, The "no video capture hardware" means that the computer cannot find your webcam. there are a several reasons why.
  1. The driver is not installed or was not installed properly. Uninstall previous driver, then reinstall the correct one.
  2. You may have installed the wrong type of driver. Check the model no. of the webcam with the device driver.
  3. The webcam usb port may be bad. reconnect to other available port.
  4. The webcam is bad, either broken wires on the usb cable or inside the camera, you may need to check for it.
  5. The PC has a virus (a very slim possibility, but viruses can change the files of the device drivers.)
If you have the time, try installing it on a friend's pc first to confirm.
Aug 31, 2009 | Computers & Internet
The computer recognizes the hardware, however scanner is not scanning. Have windows XP. How can I tell if the scanner is broken, there are no lights on it?
your scanner is ok.
But there is communication problem from computer to scanner .
For that
Check your usb cxable and usb port of computer working fine.
Try in another usb port.
If you have other port like parallel port then check it.
Check drivers of scanner are instaled proeprly.
Ig already installed then uninstall it and install again.
Also uninstall all usb drivers then restart the computer then it automatic install usb drivers .
you can uninstall usb drivers from computer with device manager.
Press windows key + Pause break key to see system proeprty then go to hardware then you see device manager then uninstall all usb drivers.
Jul 31, 2009 | Syscan TravelScan 662
Usb device not reconized, maybe need driver
You do need the drivers installed. look for the device CD or disc and install it. but if you already have the drivers installed and you still get the same message, its possible that your usb device is bad or there might be bad connection between the usb device and your computer... try to use another usb port or try to plug your device to another computer to try and isolate the problem.
Jul 11, 2009 | Alesis FirePort 1394 (ALEFP1394)
Computer can't "see" scanner even though plugged into USB port
please check:
if other usb-devices work with your pc, so usb ports of your machine are ok.
try connecting the printer to another machine, using same procedure as u did with the old one
did you get any installation cd with it?
any newer drivers for your win-system available?( inet, manufacturers homepage)
if your system and the printer passed the hardware check, install newer drivers and try again.
wish u luck
Jun 18, 2009 | Ambir Technology DocketPort 485
Usb ports
This can only mean on thing that the USB port on your computer is not properly working, what you can do here first is to run the setup CD for your motherboard so all the software including the driver for the USB port will be reinstall, if after that still not working the USB port of the computer is already bad...
May 27, 2009 | Computers & Internet
Windows xp on aspire 5735z
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Click Troubleshoot to start the troubleshooter for this device.
Well this error usually is because you have either a bad driver installed or you haven't installed any. Bad news is aspire 5735z is built for Windows Vista. Browsing the Acer website din't earn any results. Try calling in for the phone support they might have a link to where you can download compatible drivers for Windows XP.
Jan 26, 2009 | Computers & Internet
Possible usb malfunction?
hi,
well xp is a better OS than 98 ( i think) ...
few things you should know that xp is pre-installed with lotsa drivers..but on the other hand 98 isn't .. so each time you put in a USB device you need to install the driver for that device( eg your camera, pen drive etc...) . this drivers would be there accompanied with your device.
hope it helps
regards
bzoy
Jan 14, 2008 | Computers & Internet
HP Compaq Pavilion dv6110us Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
