Question about Zyxel NSA-220 (NSA220) Network Storage Server
FW Upgrade How Upgrade NSA-220 from version V2.30 (AFE.0) to 3.22(AFB.1)C0. In Firmware Release Note say: Only Supported FW upgrade from GUI when original FW version is V3.12 or later. But not say how.
Tip
Pandora's Ultimate Magic Stick 3.80M33-5
New version of UPMSv3 - universal PSP Unbricker/Downgrader/Upgrader, also known as Pandora's Ultimate Magic Stick, Now work with DC ver4 (Dark_AleX’s), for installing CFw 3.80M33-5 and creating memory stick into a “Ultimate Magic Stick” for use with “Pandora’s battery” (jigkick). Works for both PSP, Slim and/or Fat, and 1 stick for all functions for Unbricker/Downgrader tools. Also available is the “UPMS_v3.pdf Guide” to help you get started and usage.
The Ultimate Pandora’s Magic Stick is the simple solution to easily accomplish any of the following:
  • Recover any bricked PSP (Fat or Slim) and install sony firmware or CFw M33.
  • Upgrade Fat-Slims PSP to CFw 3.80M33-5, with 1.50 kernel patch-Fat Only.
  • Upgrade Fat-Slims PSP to CFw 3.71 M33-2, with 1.50 kernel patch-2 -Fat Only.
  • Update to 3.71M33-4 are installed to the ‘GAME’ folder from the XMB.
  • Downgrade Fat PSP to Fw 1.50.
  • Upgrade Fat PSP straight to CFw 3.52M33 from Extended Boot Menu then install update 3.52 M33-4 from XMB, without need to downgrade to 1.50.
  • Boot up PSP using Ultimate Loader with support for choosing which Pandora’s you reach V1, V3 or V4.
  • Boot up PSP to XMB with UPMS inserted-Fat Only.
  • Boot up to a full FW 1.50 from Memory Stick-Fat Only.
  • Use PSP Filer and other tools (If it requires 1.50, can’t for Slims).
Note: This software is free, and comes with no warranty. Despite it has been tested and it has worked, there is some risk with any PSP operation that involves flashing, so please try this at your own risk!.
Only Memory Stick "Pro Duo" are compatible. Memory Stick Duo are not supported. Read more... for installation
here.!
on Mar 06, 2008 | Sony PlayStation Portable (PSP) Console
How to upgrade my psp into a new version?
Greetings,
You have the option of upgrading your psp firmware when:
  1. You purchase a game that requires a new firmware
  2. You manually upgrade the firmware
To manually upgrade the firmware, go to the settings section on the psp. Once there, look the selection that says something like "Firmware upgrade" and press it. If there is a new firmware, it will automatically install it (*Note* You must have a wireless connection in order to upgrade *Note*) If you need further assistance, please reply to this post and I will help you the best I can. Thank you for using FixYa! =)
Dec 23, 2010 | Video Game Consoles & Games
Netgear dual band rangemax wireless router frequently drops 2.4 band connections
do firmware upgrade.
1. Please verify the model and version of the router underneath it.
2. Go to http://kbserver.NETGEAR.com/downloads_support.asp and select the model of the router.
3. Please click on the appropriate version of the router.
4. Select the link of the latest firmware. Please click on the button Right-click and Save to Download.
5. Save the file to the Desktop.
Note: Please perform firmware upgrade with wired or Ethernet connection only. Before you upgrade, write down all current settings as you need to enter them manually after upgrading.
6. Using the computer hardwired on the router, open any web browser like Internet Explorer or Netscape Navigator.
7. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
8. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
9. Click on Maintenance and then Router Upgrade.
10. Click Browse and locate the upgrade file in your Desktop. Click Upload.
11. Please wait for the router to reboot.
12. Reset the router.
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then please plug it back in.
Apr 05, 2010 | NetGear RangeMax WPN824 Router
A friend gave me a WRT54G2 without firmware
Are you able to get to the gui of the router?
If you are able to get inside the routers Gui then that would be a good sign.
Do the following:
1. Go to this site http://www.linksysbycisco.com/US/en/support/WRT54G2/download and select the version. I would suggest you to get the latest.
2. Save it to your desktop. Then extract the file.
3. launch into the router gui
4. Click on Administration then select Upgrade firmware
5. Click on the Browse button and then select desktop then chose the extracted file.
6. Click on the Upgrade button and just follow the on-screen instructions. Normally you just have to select Next.
Sep 24, 2009 | Linksys WRT54G2 Wireless Router
Unable to upgrade Zebra TLP 2844-Z printers firmware
What is the problem if this works?
May be there is a problem on the boot rom!
Jun 24, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
Mar 13, 2009 | IBM ThinkPad T43 Notebook
1140E phone upgrade
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
Mar 17, 2008 | Nortel 1140E
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Zyxel NSA-220 (NSA220) Network Storage Server Logo
161 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
