Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
I am going to buy a new free standing self cleaning stove.
I am interested in th steam cleaning feature on some new stoves. What do you think and have you had many if any questions or complaints?
  • 619 Answers
Remember this is a new feature and not sure of how it is going to work. I do know that if you have a problem down the line the repairs will be costly. Hope this helps.
Posted on Jan 31, 2010
  • 3 Answers
I think you should just clean yourself
How do you clean 1993 thermador double ovens
you can't get parts for this stove anymore so i wouldn't use the self clean on it,use soft scrub to clean it it says not to use easy off on a brand new oven but at this point i don't think it would matter on a 20 to 30 year old oven,when you put a stove into self clean it gets up to 1000 degrees,the wire casings on older stoves break down as it is but with all that heat you can do some damage to the stove,even if you just bought a brand new stove using the self clean can damage the electronics in it,usually it will take out the computer board or clock assy. same thing,your clock is most likely broken on that anyway or something else could be wrong with it and most likely you won't get it to self clean but if you want to use it or try to get it into self clean go here and read from page 32 to 36 hope this helps you out but i would not put it into self clean
http://www.servicetechhelp.com/public/user-manual/14-30-789A.pdf
if this doesn't look like your oven get the model number and google it on how to self clean
Jan 20, 2018 | Thermador Ovens
How do I turn the temp down after oven has been on for a while. 'Loc on' message is showing and will not allow me to turn oven on.
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
Feb 13, 2017 | Ovens
When trying to clean the oven, the lock on the door will not stay locked. It locks for approximately a minute, then unlocks, then relocks, etc., etc., etc. After awhile, it will give an F5 or FS (not...
I would buy a new stove if it means that much to you cause if you clean it you will be buying a new one anyway...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Nov 21, 2010 | Ovens
The circut breaker on the rear of the stove trips and must be reset every time the oven self cleanui=ing is engaged (Model # PLES399EC). How can this be fixed or prevented?
The best thing to do is not use your self cleaning feature....
Whoever invented that has caused way more problems then it solved...
It is a featured designed pruely to sell product because people are inherently lazy and because it burns up good products and then they get to sell more...
heatman101
Nov 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
SELF-CLEAN
Here is a link to your manual.
Owners Manual
FYI - The '55' in your model number should be 'ss' for stainless steel.
May 21, 2010 | KitchenAid 30 in. Architect II Series 4.3...
HOW TO USE THE SELF CLEAN FUNCTION ON A KENMORE FREE STANDING GAS STOVE
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 23, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleanning oven - door is lock and I can not get it to open
if you open the lid on your stove,you will probably be able to reset the
switch manually (the latch).with the lid up its located toward the front
behind the safety latch.(by no means attempt to force,bypass,or disable this
switch)this is a safety feature designed to protect you from the high temps
generated by the cleaning cycle.hope this helps.thanx for using fix-ya
Try this, and let me know if it worked, I am trying to help someone else with the same problem, that stove is Model, 790
Mar 07, 2009 | Kenmore Ovens
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
219 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
