After a stuck document in the printer (HP Photosmat all in one C309 series, it doesn't seem to recongize we have cleared the jam and it will now ONLY print if we use the sheet feeder.
    President:
  • 8,637 Answers
This may not help everyone that I send it to, but it is worth a try.
I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press
the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer.
The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Feb 11, 2010
How to clear a fake paper jam on an HP 7250 printer
To help you troubleshoot the error 'Paper Jam' issue, please find the link given below and follow the step-by-step instructions mentioned on it:
http://support.hp.com/ca-en/product/HP-Photosmart-C7200-All-in-One-Printer-series/3204782/model/3382182/document/c01079884/
If issue persists, it is recommended to contact HP Support Center for further assistance from the link given below:
http://www8.hp.com/us/en/contact-hp/ww-contact-us.html
GuruAid.com
May 11, 2016 | HP Photosmart C7250 All-In-One Thermal...
H0w do I insert my hp 61 ink cartridge
If you have the HP D5400:
http://support.hp.com/us-en/product/hp-photosmart-d5400-printer-series/3396078/document/c01463998/
HP provides a video to follow.
This printer takes the HP564 cartridges.
This printer does not take the HP61 cartridge.
Jul 10, 2015 | HP 564 XL Series Ink Cartridge Set for...
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
How to connect c309 printer to wireless PC
IT WOULD BE TOO LONG IF I TYPE IT IN
AND ALSO THERE ARE NO OF DIFFERENT WAYS
SO U CAN SIMPLY FOLLOW THIS LINK AND HOPE IT HELPS U
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01631592&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=3979722
Mar 26, 2010 | HP Office Equipment & Supplies
Clear carriage jam
The following video shows clearing paper jam in
HP Photosmart C7280....but it applies also for HP Photosmart C6100 All-In-One? Series :
http://www.youtube.com/watch?v=Qs-Lyw5xXLg
Mar 11, 2010 | HP Photosmart C6180 All-In-One InkJet...
It says there's a paper jam or a scanner misfeed..but there's nothing there
Paper stuck inside the HP All-in-One can cause jams or also sometimes there are some instruction that get stuck in the printer internal mechanism .
Power off the printer , unplug the power cable. Wait for 30 sec. , Replug the power cable. Power on the printer.
Check for a stuck paper or torn bits of paper.
Clear jam from the back of all-in-one
Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One.Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Gently pull the paper out of the rollers.If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If you do not remove all the pieces of paper from the HP All-in-One, more paper jams are likely to occur.
Replace the rear door. Gently push the door forward until it snaps into place.
Press OK to continue the current job.
Clear the jam from the automatic document feeder (ADF)
Paper can also jam in the automatic document feeder. Follow the steps below to clear a paper jam in the automatic document feeder(ADF)
Lift the cover of the automatic document feeder.
Reload and test the all-in-one
Once you have removed the jammed paper, verify that the all-in-one is still functioning properly.
Reload the all-in-one with either plain or photo paper.
Print a page from a memory card or the computer.
If you have completed all the steps listed above and are still experiencing a problem contact HP to service the product.
Jan 24, 2010 | HP J3680 Officejet All In One Printer
I can't clear the print qeue of my HP 1350 all in one and a document is "stuck". Won't print and wont go away.
I assume you have gone to the 'printer' screen, high-lighted the document and then clicked on delete document. This takes forever - don't know why - but it does. Eventually the document will disappear. If you don't have the patience then reboot your computer.
Aug 10, 2009 | HP Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
