Question about Memorex MP3126 Cassette/CD Boombox
Latch to hold CD top cover is broken and needs to be replaced. Where can I get a replacement part?
3 Suggested Answers
SOURCE: REPLACMENT CD LID LATCH FOR DURABRAND MOD. CD-1493
http://cgi.ebay.com/CD-DOOR-LID-LATCH-LOCKING-DEVICE-STEREO-BOOMBOX-PART_W0QQitemZ220225587206QQihZ012QQcategoryZ48626QQtcZphotoQQcmdZViewItem
Posted on Feb 10, 2009
SOURCE: Memorex CD Clock Radio # 2863. Broken latch .. will not hold down top cover
Also have the same problem, clock sat on the night stand for a couple of years. Wife took into work to play CD's at the Christmas Party and the latch failed.
Think we may have used it once or twice as a CD player.
The black latch was easy to remove, justed open up the radio and pushed in the ears on the latch and it slipped back up into the CD compartment.
Will see if I can find something to repair it. Looked like the side cracked and a housing lost some of its side.
Posted on Dec 20, 2009
Nikon D40x camera flash faulty
Depending on exactly which piece is broken, you can order the flash top cover and/or the flash head assembly.
Dec 24, 2011 | Nikon D40x Digital Camera
How to replace a headlight bulb in chrysler 300
you will need to unbolt bumper cover and pull out on side light is being replaced, doesnt have to come of completely but needs to pull back to get light out,remove the bolts from the top hold light asm, in, then remove top cross plate that holds hood latch and put to the side, then remove bolts and clips holding bumper cover and pull cover foward until you have room to pull light out, then remove the bulb from the rear,this bulbs are 90 degree plug type not the straight one, they dont fit, hope this helps, not bad to do, just sounds so.
Jun 09, 2010 | 2000 Chrysler 300M
Changing rear door latch handle
Take the plastic cover off from the inside. Fairly easy, a few bolts and some plastic clips holding it on. You may be able to open it from the outside but you'll have to take the inside cover off to replace the handle anyway. This is a common problem and if you need more detailed instructions just do a search on the net.
Mar 25, 2010 | 2000 Toyota Sienna
Door will not latch
It is likely the latch itself is broken or else the machine is in the locked position. If the switch is broken, replace it. You can get one at repairclinic.com or partselect.com
If the lock is on, disconnect from power source (unplug machine) for few hours, press and hold start/cycle button for 3 seconds and wait half hour more and pllug back in.
Dec 12, 2009 | Washing Machines
Maytag dishwasher MDBTT50AWS Door Latch broken. Screws hold the top. The bottom appears to fit into ''plastic teeth'' . Are the teeth supposed to have top and bottom or just bottom teeth. It appears mine...
can't exactly tell what you need. See if you can find it on this page and maybe that will give you an answer. https://www.searspartsdirect.com/model-number/mdbtt50aws/3048/0130000.html?sid=ps:GOOGLE:LKA_PM_Maytag_Exact:Dishwashers:mdbtt50aws&k_clickID=bc276823-c73d-402e-8108-8dca92f89665&kenibpid=p.590.bc276823-c73d-402e-8108-8dca92f89665.2138080&gclid=CjwKCAiAnabTBRA6EiwAemvBd0XpSS1QJj45nAOioA9dr98p2RxwyLGxojMnw4fEXHbDYQdSsqCFQRoCxr4QAvD_BwE
Jan 25, 2018 | Dishwashers
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Problem Printing
It appears you have a broken latch lock on 1 or both sides of the cover. There is nothing you can do settings wise. You will need to look into the printer for the broken section & probably replace the part(s) that are broken. I have a PDF file I can send you or you can download from Zebra.com RESOURCE LIBRARY section. The PDF is too large to post here. The latch is easy to replace if your slightly technical. Most replacement instructions are in the manual. Let me know if this helps.
Feb 09, 2009 | Zebra LP 2844 Thermal Printer
Feb 10, 2008 | Memorex AM/FM Clock Radio with CD Player
Memorex MP3126 Cassette/CD Boombox Logo
154 people viewed this question
Top Memorex Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
