Question about GE GDS20KBS Bottom Freezer Refrigerator
GE Bottom refrigerator/MOdel GS18LCRABB
I have had GE repair out 5X's to repair a GE bottom freeze refrigerator.  Water is collecting right below the refrigerator area and freezing interfering with a fan.  The fan can't rotate because of the build-up of ice and then the refrigerator won't cool.  So far the fan has been replaced and the thermastat.  Last "repair" the technician defrosted the icebuild-up but in a few days the ice builds back. The tech said it is common with these types of refrigerators.  The refrigerator is about 4 years old but never had this problem until recently.
  • Anonymous Nov 30, 2008
    I have the same problem although i'm not sure if the fridge is the same model but it is a GE and about the same age.
    We also have had the repairman out several times. Last time he put a small heating element in the drain pipe to see if it would prevent the ice build up. It didn't work and we just can't figure out the problem. like cimmie's fridge ours worked good for about 3 1/2 yrs before the problem started.
  • Anonymous Feb 03, 2009
    I have a GE Profile Model TCX18PAAWW. Same problem. The technician added a longer metal tube, we tilted the fridge towards the back. Still freezing up. My husband takes it apart every 2-3 weeks, uses hair dryer to thaw. There is no dirt in the tube. Tech does not know what else to do. The fridge was purchased in 1998. This problem started 2 years ago. Just became frequent in last 2 months. Still no solution. Eeggman solution is not the answer. Lorraine in NB
The styrofoam housing is more than likely saturated with water so you will have to replace this. Also, clean the drain trap and the drain hose at the back of the fridge.
Posted on Jan 23, 2010
    Problem Solver:
  • 12 Answers
I can only wonder if the drain tube has been cleaned out to make sure water flows into the pan .Also make sure it is fully defrosted and left over water will freeze quick.
Eeggman
Posted on Mar 10, 2008
Ge profile refrigerator model number tfx30pry
You have a clogged drain system in the freezer, as the unit will defrost daily, the water can't leave the freezer properly and the water collects. You need to de-ice the freezer and clean out the drain tube at the bottom of the freezer section under the evaporator. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 20, 2014 | GE Refrigerators
My freezer is collecting water in the bottom just below coils how do i repair
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRS6R4EQ4 is collecting water in the bottom of the freezer, below the coils. I also see that you think the drain is clogged. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the water is collecting. Hope this is helpful.
-Best Regards-
WP
Jun 14, 2014 | Frigidaire Refrigerators
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
Have a 23' side by side with a thur the door ice /water water is slowing dripping to the bottom of the freeezeer and freezing
That water collecting at the bottom and freezing sound like a blocked defrost heater so instead of the water draining its pooling and freezing. This tip i wrote will help ya to clear that drain. http://www1.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
GENE
Sep 14, 2011 | GE Profile 23.1 Cu. Ft. Side-by-Side...
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Water collecting at bottom of fridge. GE 17 Model 34769-3
pull bottom tray and look for hole in the back on the bottom try a clothes hanger straightened out and push thru hole
Feb 06, 2010 | Refrigerators
Water is leaking in the freezer underneath the vegetable bin. Anybody knows what the problem maybe and how to fix it?- GE MAKE 685 ENERGYSTAR
I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 22, 2009 | GE Profile¿ Energy Star® 25.5...
Ice collecting and water overflow from bottom freezer GE
IF YOU TAKE THE BACK OFF THE INSIDE OF THE FREEZER IT IS LOCATED UNDER THE EVAPORATOR COIL IN THE CENTER, IT IS A PIECE OF ALUMINUM SHAPED TO CATCH THE WATER, MELT THE ICE AND BLOW THE HOLE CLEAR
Aug 11, 2009 | GE Refrigerators
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
GE GDS20KBS Bottom Freezer Refrigerator Logo
295 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
