Question about Keurig Special Edition B60 Coffee Maker
My keurig coffee maker keeps shutting itself off. This is the second one weve had with this problem.
    Scholar:
  • 28 Answers
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. The constant reservoir adjusting may be necessary periodically and seems to be a design flaw with this model. Hope that helps! Best of luck...
Posted on Feb 07, 2010
Shutting itself off
There are a couple reasons that the B70 might stop in the middle of brewing so one cannot be certain. The first one is where there are calcium carbonate deposits on the heating element and as the water in the boiler is agitated during pumping there is inadequate heating from the heating element and the thermostat shuts the brewing off when cooler water rises to the thermostat. Try running a mixture of 50/50 white vinegar through the unit a couple timesxto dissolve the calcium deposits or descale the unit per Keurig instructions. Secondly, it could be a faulty thermostat. If you are not handy, mechanically oriented I suggest buying a new one is best, least expensive. I believe that keurig coffee makers are able to brew 5000 cups without a problem. However our experience is that units with more than 5000 brews are prone to leakage, electricalr problems.
Aug 04, 2014 | Keurig B70 Coffee Maker
My K10 mini keeps shutting itself off
It is normal for a Keurig mini to shut itself off after 90 seconds of inactivity. Reference page 17 of the manual.
https://www.greenmountaincoffee.com/~/media/B2C/Files/Keurig%20Brewer%20Manuals/B31MiniPlus_manual.ashx
Feb 19, 2014 | Keurig K10 Mini Plus Single-Cup Coffee...
I descaled my coffee maker with 1 1/2 gal vinegar after flushing all the vinegar through it, the descale sign went off but now the coffeemaker keeps shutting itself off. It is "toast?"
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 08, 2011 | Keurig Platinum B70 Coffee Maker
Hi, I descaled the machine and it just wont stop draining. Occasionally it will shut of by itself while draining. thanx
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
May 14, 2011 | Keurig B30 Mini Coffee Maker
Never gets ready, keeps shutting off.
Try using a straw. Use it to blow thru the hole where the reservoir attaches. I tried this on my B40 and worked.
Feb 23, 2010 | Keurig B70 Coffee Maker
My almost new Keurig (which I LOVE) keeps shutting down
I am having the same problem and will report back here if I find an answer. If I keep turning mine back on, wait for it to go off by itself. Turn it back on again...and again. Eventually I can get a cup of coffee. But my one-minute coffee cup usually takes 15 or 20 minutes.
Mine was a gift, so I'll probably just see if I can swap it out.
Cuz that's some good coffee.
Dec 13, 2009 | Keurig B100 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
289 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
