Question about Compaq AlphaServer DS10
ALPHA SERVER DS10 with OPEN VMS 7.3
The server is not booting up. Currently when we start up:
1. it beeps 6 times.
2. the hard drive light remains on.
3. the fan light remains on.
3. it cuts off on its own.
Initially only #1 above was occurring. Then #1 and #2 started occurring. Then #1 to #3 started occuring. Now #1 to #4 is occurring.
Any information on the cause and the solution would be appreciated.
Thanking you in advance
S.S.
  • Narvaar Apr 12, 2008
    Thanks for the help, I still need to get RAM in order to test it though
  • Anonymous Jun 09, 2008
    If replacing memory does not help, try to replace PSU.
  • 4 Answers
DS10 - Six beeps indicates that a checksum error has occurred after the ROM image was copied into memory. Probably either memory is misconfigured or a memory DIMM needs to be reseatedor replaced.
Dave
Posted on Aug 05, 2012
    Sergeant:
    Champion:
  • 277 Answers
Check the computer memory Ram and the processor
Posted on Mar 07, 2008
How many OS supporting alphaserver ds10
HP Open VMS, HP Tru64 Unix, Linux, MS Windows
Oct 29, 2013 | Compaq AlphaServer DS10
I have ML350 G3 Server SA 532 and 2 HDD SCSI, W2K. I want intall RAID 1 Can I help me???
unable to understand your question.
If you want to configure raid 1 and install OS freshly then follow these steps.
1) make ready all the required h/w.
2) Swith on the server.
3) when post starts reading SA532 controller press F8 button .
4) you will enter into Raid card bios.
5) select View to know any existing logical drive.
6) select Create logical drive,select both hdd's by pressing space bar.
7) press F8 to confirm changes,save and exit.
8) Enter into bios and set the boot controller order smart array controller as 1st.
9) press escape button and restart the server.
10) boot with cdrom and proceed for os installation.
6)
Jan 19, 2011 | HP Compaq ProLiant ML350 G3 Server
How to download hwk update client v 2.1.0
Upgrade log:
---------- HWK Update Client v 2.1.0.0 ----------
---------- HWK upgrade started:6/2/2011 6:35:55 AM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 78650
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-DE6985914260006D
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication stage error: Error: Server returned unrecognized reply
Oct 07, 2010 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
Hoow do you open gateway MX6440. No audio. Bootup
Typically, a computer tries to "boot" from several devices:
1. 3.5-inch diskette
2. internal CD-ROM
3. internal disk-drive
4. USB memory-stick
5. network (if a "boot-server" can be found on the network)
6. external diskette
7. external CD-ROM
8. external disk-drive
So, in your case, either
* the "boot-order" _EXCLUDES_ your disk-drive,
* your disk-drive is not connected,
* your disk-drive is connected, but is "dead" (not responding)
Not being able to boot from the disk-drive, your computer probes, via the network, for a "boot-server". Finding none, your computer reports, in a strange way, that "network cable is not connected to a boot-server".
So, the "check cable" means that the Ethernet cable between the network-port on your computer and the boot-server may be "unconnected".
What this could mean is that your disk-drive is "dead".
Take the computer to a qualified technician, for more trouble-shooting.
Nov 18, 2009 | Gateway MX6440 (6585) PC Notebook
I have a COMPAQ 1000 Alpha computer running OPENVMS 7.2 and recently the system has not been able to access the hard drive. I am able to see the device intermittently but it fails after a short period of...
You have not provided much to go on here. Is the system up and running or do you have only a single drive? You should be able to do a "SHO ERR" and see any errors logged to the errlog that will indicate the hardware issue. Using "anal/err" or Clue, you should get the error details. Please post what you find here and I'll provide suggestions.
Dan
(30+ years of VMS experience and still going!!)
Jun 11, 2009 | Compaq Alpha Server 1000, 400MHZ...
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
Recognising floppy disk drive type on DS10
the Only VMS post on fixya ever.
wow. from the dark ages of DEC. VMS. OS.
sounds like bad drive if it can not be mounted.(or disk bad)
sounds like you are 42 years behind the upgrade curve too...
i used to work on all DEC systems. so know that . 1975
the DS10, is now 18 years old.
here is a relic manual, on that
http://zzz.physics.umn.edu/_media/computing/department/ds10-cr.pdf
is this your only DS10, of not try the drive on system #2?
ahh its now called OPENVMS,, amazing thing that is.
open vms was ported to ALph chips. 1992
then 2001 port of OpenVMS to the Intel Itanium architecture
so it's an 17 year old OS.
get HP proliant Server G7 up. and win. for sure.
Dec 13, 2017 | Compaq AlphaServer DS10
Help with server boot problems flashing orange lights etc
Seems the RAID is broken. You may see which drive (hot swappable?) it showing an error code with its lights in front. If not, I would suggest re-seated all drives.
If you see one that is not right, remove it all the way, while it is on, then push it back in, it should try to rebuild the raid on the drive, if it still fails, you will need to replace the drive.
Not sure what RAID you are using or how many drives, so feel free to explain more.
G'luck
Oct 24, 2008 | Dell PowerEdge 4600 Server
Response to constant beeping on the dell 1600sc server
Please provide me a complete list of components on your server and I will be more than happy to help..
Regards,
Sai.
Oct 06, 2008 | Dell PowerEdge 1600SC Server
DS10 with SBS PCI Expansion
Version 7.1-2 is an older version of the OS. I will have to check, but I think that V7.2 will resolve this. What version of TCP/IP are you using? Back in the day when I supported TCP and VMS, there were some timing issues that causes odd behavior. If you can provide the details about your configuration, I can check and get back to you. If necessary, an examination of a forced crashdump may be needed.
A rare opportunity to work with VMS again!!
Good stuff.
Dan
Aug 01, 2008 | Compaq AlphaServer DS10
Compaq AlphaServer DS10 Logo
876 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
