Question about Sony Cyber-Shot DSC-S40 Digital Camera
A brownish liquid inside my s40
Last day..
i oppened my s40...cause im so fasturated by the lens stuck..
i got to opened the back cover.. but not the front cover...
i see a drop of brownish liquid inside my camera.. its like a batery fluid..
anywonder how..
and i cant fix the lens too...
thx
  • cimbuak Feb 21, 2008
    but the camera funtional well.. but cant opened the lens...
  • 477 Answers
This sounds like you have a popped compasitor a compasitor has brown liquid in it that is a form of oil that makes the compasitor work if the get overloaded for some reason they pop. Beleave me that sucks. It can be fixed but it sound like it might cost more that the camera is worth. Up to you. Sorry for the bad news. :(
Posted on Feb 20, 2008
  • Mike Johnson
    Mike Johnson Feb 21, 2008
    if the camera is still working then it is not the compasitor the liquid is most likely not your problem. as far as the lens you can get it fixed or you can get a as is camera off ebay for a decient price that has something other wrong with it and take the lens out of it .
    but i do advise having it repaired by a expert but if you chose to do it on your own try and find a service manual first it will give you the disasimbly instructions.
We went to the beach yesterday and after the whole day was done my camera lens is stuck open and it wont turn on when i try it makes a weird noise and turns back off.
I would try to gently push the lens back in hoping itll click into place..but thats risky!!!You can take it apart and try to ge the lens in this way, But again,Risky! Last thing:
Send it in for service. The manufacturers' warranty seldom covers abuse though. If it isn't covered, the repair cost will likely exceed the cost of a new camera.
Jun 15, 2010 | Cameras
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
My camera says "Turn the power off and on again"
easy! charge the battery.With power off,whack the base of the camera against the palm of your hand four or five times.wait five minutes,turn camera on and whack the side of the camera nearest the lens against the palm of your hand.then whack the base again and the lens should pop out.Worked for me!!!
Nov 13, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony DSC-S40 stuck lens, won't turn on...
About the LCD turning white, it an indication of a defective LCD, About the lens stucked-up its a lens problem, It will be solved if the LCD and lens assy's be replaced. thanks
Sep 08, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera lens cover is sticky
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Sony Cybershot Lens Stuck inside!!!
Gently tap it on a table or flat surface a few times. Worked for me!
Jul 06, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
The lens cover wont open
If debris like sand or dirt get into the mechanism which closes that cover it will jam shut. Try gently placing something pointy in the gap between the two blades of the cover. Do not force them apart, if this is going to work they should free with very little pressure. Be very careful not to touch the lens especially if you are using something metal to separate the cover.
Feb 13, 2007 | Nikon COOLPIX L4 Digital Camera
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
29 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
