Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker. The first solution is simple, change icemaker water filter and disassimble valve to clean. The second is simple, buy a new icemaker.
The water inlet valve(where the water supply connects to the back) may have been staying open and now has burned so it don't work at all. . You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Replace the water valve on the refrigerator. The valve solenoid is stuck open causing water to flow freely. This should fix both issues with icemaker fill tube freezing and water dispensing.
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
You have a solenoid switch which switches the
dispenser back and forth from crushed to cube. It could be stuck or not working
or the parts connecting it could be disconnected or broken. You will have to
observe to see if any parts are moving and if any noise is coming from the
solenoid
Can you confirm please does it dispense water by itself if you select water? have you tried lifting the ice maker stop lever by hand? At a guess from your fault description I'd say you need a new dispenser micro switch. at worst a new Ice maker unit inside freezer. cheers
