Question about Bosch Ovens
My Bosch combi oven HBC84K5 is fantastic to use but I cannot keep it clean. Everything I cook in it seems to weld to the surfaces. The instructions say do not use anything abrasive, wipe is with detergent and a soft cloth - which doesn't do a thing. I have tried Barkeepers friend, several different detergents, a spray oven cleaner from Lakeland etc but to no avail. There is no self clean mode and as the instuctions say no steam cleaning - I'm foxed. Can you help?
  • 1314 Answers
SOURCE: door won't open after self cleaning.
it is locked the leaver has become detached from the door latch and even though the leaver moves the lock part doesn't have you tried it lately push in on the door and try to move the leaver if that doesn't work get a wire coat hanger make a Small hook and from the left hand side see if you can snag the hook and pull it over ive done that before theopen end of the hook should point up start just abve the door gasket about halfway over well i cant reamber which way the latch moves but im sure you can figure it out push slighty in on the door after you hook the latch but try to open it fist some have asensor that wont let the oven door open till its cool enough to be safe let me know
Posted on Dec 31, 2007
  • 1314 Answers
SOURCE: self cleaning lock
well i don't know how long its been off but most have a safety feature that wont let the door open till it senses its safe can take an hour if its not malfunctioning reply and let me know how long its been
Posted on Jan 20, 2008
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
  • 46 Answers
SOURCE: Oven cleaning bosch oven
self cleaning is sometimes a cycle called PYRO clean / look for the setting with a really high temp. self cleaning is a programmes require a massive amount of heat and will smoke a lot when on , so dont be alarmed! most oven when on self cleaning mode will automaticly lock the door due to the high heat involved in the process. so remember to remove pans etc. from inside.
Posted on Feb 11, 2008
  • 10865 Answers
SOURCE: hotpoint oven self cleaner mode; cant unlock the door
Hello. I want to help you. I can understand why you did what you did. Now though I want you to forget about the open cleaner and just set the self cleaner again and let it run its course. get back to me if it won't let you do that as there are other things you can do then.
Posted on May 20, 2009
How to set cooking timer on pyrotechnic Bosch oven?
Here's the link to the manual page. Without the model number, I cannot give you the proper instructions but this page will tell you where to find your model number, then link you to the manual as well. Good luck!
BOSCH Customer link:
https://portalcn.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
Jul 16, 2014 | Bosch Ovens
Oven cleaning instructions
Look at the finish of the inside surface. If it looks dirty then it should be cleaned. You can use some foam products such as EasyOFF. Instructions are on the can. Follow them and don't breathe any of the fumes that propagate in the air. Keep a window open, just in case.
Nov 03, 2013 | Frigidaire FGB24S5A Gas Single Oven
How do I get the door open after self cleaning and what do I push to self cleaning
Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
Instructions
Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
Tips & Warnings
Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
Hope it helped.
May 28, 2011 | Ovens
I'm trying to clean my Bosch oven, model number HES5052U, and twice now it gets 30 minutes into the self-cleaning cycle and then it shuts down... flashing Error 41. Everything seems to run smoothly until...
Allow the oven to cool before running self-clean. Always wipe out loose soils or heavy spillovers before running self-clean. If oven is badly soiled, set oven for the maximum self-clean time.
Here is the manual with "troubleshooting". Hopefully, it will help!
Operation Bosch HES5053U 31 100
Jun 29, 2017 | Bosch Ovens
The oven keeps beeping and displaying F10 on the screen when we try to cook anything.
HI. this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
Oct 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
Ovens Logo
167 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
