Question about Linksys EtherFast Cable/DSL Router
Etherfast cable/dsl router with 4-port switch
At the end of setup It asks for status wwwwhen Iget to the end of the status It wont acept it
    President:
  • 2,351 Answers
When i put in default username and password says its not authorized
Try admin in user anme and admin in password.
If that doesn't work then try admin in only password, leave the user name blank.
If that doesn't work then try some different passwords that you use often.
If nothing is working then you will need to reset the router.
Once you reset the router, you will lose all the settings on the router and you will need to reconfigure it.
See How to setup Linksys router
Apr 23, 2012 | Cisco Linksys EtherFast Cable/DSL Router...
Internet connection failed
Well the first thing to do is try to isolate the problem. Before we start make sure the 1st PC will give the same network cable unplugged error if it too is unplugged. Once that is done start by unplugging the network cables from the PCs and switch them. Does the problem stay with the 2nd PC or does it move to the 1st? If it stays with the 2nd PC then the problem is with the PC network card or more likely its configuration. The network card should be configured exactly as the 1st one, probably to obtain the IP and DNS addresses automatically. If you need help with this let us know the operating system you are using. If the problem moves to the 1st PC that indicates the problem is with the cable and/or the router. Now switch the cables at the router end, if the problem stays on the 1st PC then that network cable is your problem. It could be a ?cross-over cable or simply damaged. If it doesn?t move then the problem would be in your router. Either that router port is bad (try using another port) or the one port that works is configured uniquely. You?ll need to take a look at how your router ports are configured and look for the differences. Let us know what you find and we?ll go from there.
Jul 30, 2007 | Linksys Instant Broadband EtherFast...
TRYING TO HOOK UP ANOTHER COMPUTER
put the internet cable and ethernet cable in lan port then try to ping the google or yahoo or something else like that start-->run--->ping google.com -t
May 19, 2009 | Linksys EtherFast Cable/DSL Router
Wired router keeps cutting both computers off
Check you wall plug power supply, they get bad not long after they are put to service. Find a replacement power supply with preferably higher current rating and your problem goes away.
Dec 21, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Configuring DSL for All RJ-45 Jacks
the simpliest way is to have a wireless/ wired 4 ports router and install it beside your modem and locate where your Cat 5 cables central end is. Identify the Cat 5s that are connected to the 5 locations of your PCs if all of them are not capable of wireless connection you need to add a switch (4 port or 8 port) which you also need to connect to one Lan port of your router.
Hope this helps.
Apr 11, 2008 | Computers & Internet
Linskys etherfast cable dsl
chak your connctivity pc to router by ping
your router defolt ip is 192.168.1.1
so go start run type ther ping 192.168.1.1 -t
so come reply so its conneted with your pc
then reconfiger it
Feb 25, 2008 | Linksys EtherFast Cable/DSL Router
Problem with post forward
I HAVE ONE OF THIS ETHERFAST CABLE/DSL ROUTER BUT I CAN INSTALL...CAN YOU HELP ME????? PLEASE
Feb 03, 2008 | Linksys EtherFast Cable/DSL Router
Wireless router
modem to inter net or wan port on this router>and u have 4 ether net od lan use any one -->ether net cable to pc's>and if u r using cable inter net then reboot the both router and modem u can get inter net access if its dsl contact linksys cause need to configure teh router rate me solved if its help full thx
Oct 29, 2007 | Linksys EtherFast Cable/DSL VPN Router...
Linksys EtherFast Cable/DSL Router Logo
75 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
